  • SN95 4.6L Mustang Tech
96 Cobra Overheating
  • Thread starter Thread starter daneCobra
  • Start date Start date Aug 2, 2004
D
daneCobra
  • Aug 2, 2004
While I'm driving, the tempature gauge goes way over hot, then the coolant light turns on and it drops back to normal. This has been going on for a couple of days. Yesterday I got out and antifreeze was bursting out the cap. I went and bought a new thermostat and new coolant. I drained out the radiator, but where is the thermostat located? I can't find it (If you haven't noticed, I'm no mechanic).
Where can I go to see how to replace the thermostat preferably with pictures , and does anyone else have any other ideas on what is wrong? The radiator shop will rod it out for $300, but I'd rather try the thermostat first.
I'm not aware if it went in for the cooling recall back in the day. I have owned the car for a little over three years and it has almost 60,000 miles on it.
Thanks,
Dane
Aaron 4.6
2,695
Georgia
Aug 2, 2004
  • Aug 2, 2004
The cooling fix didn't always fix the problem. A better radiator like a Fluidyne might be the solution. You can find the thermostat in the silver housing at the bottom of the rubber coolant hose. Its on the drivers side a little ways in front of the oil filter. Check the cheapy thermostat first, but I'd go with a nice aftermarket radiator before paying $300 to service the crappy OEM one.
D
daneCobra
  • Aug 3, 2004
Thanks for your help
I switched out the thermostat and I put in new coolant. Everything seems to be back in normal condition. I will watch the coolant level for the next couple of days to see if it changes.
Thanks for the help Aaron.
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
M
1997 Mustang GT Overheating Issue
  • Mustang1988!!
  • Sep 3, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
squeak93
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
