  • SN95 4.6L Mustang Tech
'96 GT Automatic Transmission Problems
  • Thread starter Thread starter king burna
  • Start date Start date Jan 22, 2010
K
king burna
  • Jan 22, 2010
i recently got in my car and it would not shift past thirty miles an hour. So thats either 2nd or 3rd gear i cant get into. I can drop it into 1 and shift into 2 fine, but when i try to shift from 2 to D it just revs higher and wont shift. All stock, any ideas.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jan 22, 2010
  • Jan 22, 2010
What is the condition of the transmission fluid? Color (red or brown)? Smell(sweet or burnt)? How about the level (too low or high)? How much friction material is in the pan?
If the fluid is OK, suspect a problem with the:
Shift Linkage,
Digital TR Sensor
2-3 Accumulator
G
gtstangkid
  • Jan 24, 2010
transmission
i have a 98 gt wit the same problem wit mine i had to rebuild some internal parts failed
nyuk98gt
1,427
Chesterfield, MO
Jan 25, 2010
  • Jan 25, 2010
king burna:
Read "Transmissions 101" at TCCoA.com (Tech Articles/Transmissions). This series of articles was written by Jerry Wroblewski, former Ford Transmission Engineer. A couple of articles describe the famous "J-mod".
wmburns:
What about solenoid failure? There are two of them and they do go out. (I'll check my ATSG booklet after work because I don't remember the various on/off pairs for the 2-3 shift.)
Chris
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Jan 25, 2010
  • Jan 25, 2010
nyuk98gt, Good point and nice reference!
However, in my experience often times most any transmission problem can be traced to the poor condition of the fluid. I am afraid many ppl don't perform transmission service until it starts acting up.
It seamed premature to go very far until the OP performed basic fluid maintenance and confirmed the problem was still there after fluid service.
nyuk98gt
1,427
Chesterfield, MO
Jan 25, 2010
  • Jan 25, 2010
Mr. Burns (but not Homer's boss??),
Thank you. I defer to your superior experience. You are quite correct about fluid condition (level, age) being a big factor.
Let's see what comes up next with this trans.
Chris
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
