  • SN95 4.6L Mustang Tech
96 Gt not starting?
  • Thread starter Thread starter cleanbutslow83
  • Start date Start date Jan 27, 2011
cleanbutslow83
  • Jan 27, 2011
Hey everyone I am new to this forum and I have a current problem with my 96 Gt that does not want to start. It cranks until the battery dies but it won't turn over and I have currently replaced the fuel filter and Ign. switch and still nothing. I have checked to see if the fuel pump is working correctly and it is, the car has plenty of fuel pressure and spark. I have heard of the PATS system having problems but it doesn't seem to be this either, I can spray starter fluid into throttle bottle and the car will run 3-5 sec. and it shuts off which also tells me there is good spark but at this point I am cluess I am currently thinking about bad gas maybe. The car has sat outside for 3-5 months and it was running just fine before, the filler tube gasket at the gas tank has torn and the car was leaking some fuel before I let it sit, would this cause any problems? I am so frustrated and can't seem to figure this one out, any suggestions will be greatly appreciated.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Jan 28, 2011
  • Jan 28, 2011
check fuses and grounds to PCM , sounds like the injectors are spraying for some reason , is the theft light blinking when you are trying to start it ?
keithnra
53
  • Jan 28, 2011
Yes check to make sure u have power to the computer
trinity_gt
3,125
81
99
Canada
Jan 28, 2011
  • Jan 28, 2011
2002BLGT said:
check fuses and grounds to PCM , sounds like the injectors aren't spraying for some reason , is the theft light blinking when you are trying to start it ?
Fixed it for ya and I agree.
OP how did you ascertain that there's plenty of fuel pressure?
cleanbutslow83
  • Jan 28, 2011
I have checked the fuses and found a 40amp blown for the rear defrost but that's all I found. PCM is getting power and I checked the fuel pressure by using the valve on the fuel rail and it has a ton of pressure behind it, it shoots fuel out like a mad man lol. The theft light is not doing anything different, it doesn't flash it cuts off once the switch is on for 3-5 sec. I was thinking maybe it was the PATS transciever but it doesn't seem to be that as I have tried my extra key as well. Where would the grounds be for the PCM, I will check those as well but these are great suggestions thanks for your input.
cleanbutslow83
  • Jan 28, 2011
BTW I hooked my programmer up to the car and got plently of readings for codes etc. I figure this couldn't be done without the PCM working.
R
rockyracoon
874
27
49
margate NJ
Jan 28, 2011
  • Jan 28, 2011
can you ascertain whether or not the injectors are firing?I believe you can buy something called a noid light to check them.
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
