i heard that u dont need bump stops with after market shifters with the t-45 tranny. thanks and post if uve heard this i wanna find out if i need my bump stops in
-Clears throat- t-45 + Hurst shifter from previous owner + bump stops = F***ED up tranny! My tranny pops out of second constantly if you try and gear down due to under shifting caused by bump stops...DONT put them in ..The boards a full of people having similar grinding and popping problems after using bump stops and thats BC tremec jsut recently decided to fill everyone in on this...If you put them in you wILL regret it!
tell that to my old t-45 with a stock shifter.....if you can find it....it should be in scattered pieces at Englishtown Raceway, NJ.
sure you dont NEED them, but a good shifter (notice i said GOOD) with em will save your transmition when powershifting. It is real easy to hit 2nd or 3rd gear real heard and completely bend or break off the shifter fork....bum stops will stop the handle before you do this. If you adjust them right, they are a great thing to have.
if they do have effective stops how does everyone rip through the shift forks with the stock shifter?? The people who have problems with them dont set them right. there should be a slight gap between the handle and the stop when it is in gear, not resting on it....this way you dont get undershifting (root of all those problems) and you still get the protection.
