96 to 99 engine swap questions
smenzel444
I'm planning on puttin a 99 4.6 SOHC in my 96 GT. I notice a couple problems already. I have the complete engine with harness and TB. Any advice would be appreciated.
1. The 99 has the coil on plug setup, can I use this with my cars wiring?
2. The fuel rail doesn't have a return, it has an electronic regulator or something on the left bank. What do I do with my original return line?
I was thinking of just using my 96 fuel rails, but then what will happen with the electronic regulator plug?
I could also use my 96 coils and harness, but I see some other differences in the wiring on the 99.
I think I'll quit now and let some of you experts tell me what's up.
Thanks a ton.
You'll also need to tap the aluminum cross-over on the intake for the second temp sensor. If you don't have the aluminum cross-over, or you don't want to remove it to get it tapped, look on the side of the block for a plug that you can remove and screw the sensor in. Some people [I can't seem to think of who it was :D ] use a T fitting in the one provided sensor hole and then screw the two sensors into it.
