My 97 has 150Kmiles on it and its losing about 4 quarts of oil every oil change, there is leaking but very minimal, but my coolant reservoir has plenty of oil in it but my oil doesn't have coolant in it. I was thinking of having a mechanic tear the engine down and just rebuild it. What critical parts should be replaced and it is as simple as removing the old parts and replacing the new ones? I have PI heads on the car already, so I was thinking of getting those port and polish also, Do i have to do anything special to the block? better pistons? do they just swap in?
What websites to go to purchase these items for the best value? I will like a bit extra power, i am definitely not looking for any power adders, just motor work.
What about cams, what do you all suggest, the car will be a daily driver, and my budget for parts and labor is $3000. How much will the rebuild part cost approximately?
Thanks for the assistance.
The ptv problem is on the outer part of the piston, the dish of the piston is not the problem. The only way to run an aggressive in these motors is to get the pistons notched.
