'97 Grand Marquis, updated intake, coolant gauge sender problem
fiveofanatic
How to fuel a Mustang:
8,152
Phoenix, AZ suburbs
Ok. The sending unit for the gauge (digital dash) mounts into the coolant crossover, which is now aluminum instead of plastic. The sender appears to be shorting to ground on the aluminum crossover (the gauge goes ape**** with the sender installed & connected; the gauge partially blanks out). The original sender did this, the replacement sender does it. Remove either sender & heat it artificially, & the dash gauge displays the temp increase properly. No gauge problems with the old intake with plastic coolant crossover.
The sender for the pcm appears to be working ok; no codes. I've been involved with several intake swaps to the updated design, & have never seen this. I can't recall if any of the others had the digital dash, though.
Any ideas?
post this at modulardepot.com under the ford parts section and see if randy knows of a sender that will fix the problem .... im sure there is something that will work ....just need the right sending unit ....
