97 mustang GT no start. Please help!
G_woodson
Memphis
So I just bought my first mustang two days ago everything was going good until I attempted to back in my driveway. When backing up the car completely shut off, and when trying to turn it over it just clicks like a bad starter. I’ve checked the battery connections everything is good the car has power but will not do anything but click. Seeing as it just turned off I don’t think the starter is bad. Has anyone ever had this problem before? I’ve also tried to pop the clutch and that won’t even start it.
  • Sponsors(?)
GDawg
1,463
Colorado Springs, CO
Need more information... So when you turn the key do the dash lights and gauges come on? You don't hear the starter turning so you have "no crank"? Have you checked the voltage on your battery? What is the voltage on the battery? Let's start there.
wmburns
SN Certified Technician
Aug 14, 2009
5,818
500
194
Houston Texas
I agree. If it shut off then it's likely electrical. Focus on:
  • The battery.
  • The battery terminals. Especially the battery negative as it's bad about splitting.
  • The ground. Especially the ground from the radiator core support that goes around the battery.
  • Confirm there is +12 volts at the alternator B+ main terminal.
Don't cut corners on testing the battery and alternator.
Low tech battery voltage tester. Turn the head lights on. Are they bright? What happens when you attempt to crank? Do the head lights stay the same, dim, or go out:?
Howto perform charging system voltage drop test
https://www.stangnet.com/mustang-fo...perform-charging-system-voltage-drop-test.56/
Test for key on +12 volts at each (or one to confirm basic power) fuel injector and the TPS. Use a known good ground.
1996+ Crank with no start check list
https://www.allfordmustangs.com/forums/4-6l-tech/336452-1997-mustang-wont-ignite.html
G_woodson
Memphis
I’m deployed so I’m having my buddy check it for me. I was on a video call with him when they were attempting to start it. So when you turn the key on volt meter in the car is reading 12v when you try and turn it over there is just a single click. Also while trying to start it the battery drops. There isn’t a sound of the starter trying to turn over just one click. Attempted to start it with jumper cables nothing. Tried to dump clutch while rolling it nothing. It all started when they went to back it in my driveway he said it scraped a little and just turned off. All gauges and some lights work
G_woodson
Memphis
Also checked all the fuses and relays all were good so what all grounds should I check. I heard these cars have some crazy ground locations. This car is especially hard to get under since it’s like two inches off the ground
GDawg
1,463
The gauges in the car are just for show. Don't depend on the voltage one to be accurate. The battery should have a voltage of at least 13.5v (14v preferably), not 12v. 12v is too low to start a car. I think when it's sitting, 12.7v is okay but no lower. But if it's just the battery, a jump should start it. If the battery is fine the next thing I would do is get under the car and see if the voltage is being delivered to the starter. I think there is a fusable link between the battery and the starter. WMBurns would know.
Neuron
Mustang Master
Nov 6, 2016
790
171
83
70
Follow wmburns advice if you want to fix it. Of course if you have money to burn then just throw parts at it(starting with the battery).
Thank you for your service and be safe.
G_woodson
Memphis
Thanks guys I’ll let my buddy know what to check. But he’s not mechanically inclined at all so it’ll probably just sit for the next 7 months lol. Thanks for all yalls info.
Thread starter Similar threads Forum Replies Date
C New Fuel pump, wont start. Please Help! 99 V8 Mustang GT SN95 4.6L Mustang Tech 9
N Please Help I'm Having Trouble with my 1994 Mustang GT 5.0 1994 - 1995 Specific Tech 6
starstruck106 Car overheated and now it won't turn over - help PLEASE 1994 - 1995 Specific Tech 51
B Can someone please tell me what security system is installed on my 95 mustang 3.8. VIN: 1FALP4041SF249366 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
S Mustang 93 5.0 doesn’t start cranks but no start please help... Fox 5.0 Mustang Tech 35
W Engine 89 Mustang Gt Wont Spark. Wierd Situation Please Help!!! Fox 5.0 Mustang Tech 7
M 2002 Mustang Won't Start...please Help 1996 - 2004 SN95 Mustang -General/Talk- 1
C Please Help 99 Mustang Not Starting SN95 V6 Mustang Tech 0
M 08 Mustang Gt Starts At Times, Wont Start Running? Help Please!!! 2005 - 2009 Specific Tech 16
P Help, Please! 2001 Mustang Won't Start, Fast Clicking. I Know The Exact Moment That Caused It. SN95 V6 Mustang Tech 2
P Help, Please. 2001 Mustang Won't Start, Fast Clicking. I Know The Exacat Caused It. 1996 - 2004 SN95 Mustang -General/Talk- 2
M 1989 Mustang Gt Will Not Stay Running At Cold Start Up. Please Help! Fox 5.0 Mustang Tech 15
Mogulous Please Help, Urgent-1998 Mustang Wont Start SN95 V6 Mustang Tech 2
U 95 mustang gt dies when driving starts back up or some times it wont? help please 1994 - 1995 Specific Tech 3
B Mustang Won't Start Please Help Fox 5.0 Mustang Tech 7
R Please Help 92 Mustang won't start! Fox 5.0 Mustang Tech 7
Z Starting a mustang store... Please Read! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
N Progress Thread 1984 mustang gt350 will not start Fox 5.0 Mustang Tech 0
B [Project Car] 1986 5.0 V8 Foxbody Mustang Starting Issue Fox 5.0 Mustang Tech 8
H 2003 mustang v6 tick on start ups. SN95 V6 Mustang Tech 5
C 88 Mustang won’t start? Fox 5.0 Mustang Tech 5
M 2001 GT no start electrical issue SN95 4.6L Mustang Tech 10
T No power to the MAF Sensor 1996 - 2004 SN95 Mustang -General/Talk- 0
D 2001 Mustang GT will crank but not start SN95 4.6L Mustang Tech 3
D 93 2.3 crank but no fire 2.3L (N/A & Turbo) Tech 18
C 2016 Mustang V6 will crank but not start 2015+ Specific Tech 2
Woody3882 Did you start the restoration in Arkansas of a 1965 Mustang coupe and sold it in May of 2014 Regional Forums and Event Information 0
J Start a car club in Lancaster/Palmdalr area Regional Forums and Event Information 0
T Cranks but wont start 2.3L (N/A & Turbo) Tech 4
K Engine 89 mustang lx 2.3 Starting problems 2.3L (N/A & Turbo) Tech 11
D 95 mustang 5.0 no crank no start, went thru checklist.. 1994 - 1995 Specific Tech 1
nathanruschill 2000 Mustang Gt auto starting issue!! SN95 4.6L Mustang Tech 3
S 2000 Mustang V6 wont start SN95 V6 Mustang Tech 1
P 2003 mustang GT cranks but doesnt start 1996 - 2004 SN95 Mustang -General/Talk- 3
W 1998 v6 3.8l mustang cranks but will not start 1996 - 2004 SN95 Mustang -General/Talk- 4
1989FoxFan Engine How To Start 89 Mustang GT after sitting for 10 years Fox 5.0 Mustang Tech 5
E 2010 Mustang GT - randon, intermittent, fresh hard starts with rough idle. 2005 - 2014 S-197 Mustang -General/Talk- 0
B Crank no start 99 4.6 . Gets fuel, obd read p0606 not sure to replace pcm SN95 4.6L Mustang Tech 1
B Engine Crank no start 99 gt 4.6l supercharged. Advice needed SN95 4.6L Mustang Tech 5
C Gauges on 2000 gt slow to work after starting 1996 - 2004 SN95 Mustang -General/Talk- 6
C 2002 v6 mustang dead battery now won’t start.. 1996 - 2004 SN95 Mustang -General/Talk- 7
0 02 mustang starting problems... SN95 4.6L Mustang Tech 1
G 96 GT cranking but won’t start SN95 4.6L Mustang Tech 1
C Theft sign solid; car won’t start. SN95 4.6L Mustang Tech 2
1 1990 mustang gt running like crap when hot,but good when first start up. Fox 5.0 Mustang Tech 18
H 66 mustang cold start blows a little carbon. 1965 - 1973 Classic Mustangs -General/Talk- 4
Drum4life23 I have a very interesting situation! 06 mustang won’t start unless I remove fuse HELP! 2005 - 2009 Specific Tech 4
N Engine 2001 Mustang Bullitt Starting Problem SN95 4.6L Mustang Tech 4
C 98 mustang gt won’t start SN95 4.6L Mustang Tech 7
D 2000 Mustang V6 cranks, no start, and no fuel pressure (BUT has started intermittently) SN95 V6 Mustang Tech 3
