  • SN95 4.6L Mustang Tech
97gt needs upgrades
  • Thread starter Thread starter stang_man_1
  • Start date Start date Feb 18, 2006
stang_man_1
24
  • Feb 18, 2006
Hi
I got a 97 gt a while back and i just found out that it has
had a PI intake swap done. Does any one know how much power this swap is worth. And does anyone have any idea what temperature i should set the thermostat to.
It is and automatic with headers, flowmasters, a K,N
filter, and the PI swap. My best time was 14.5 @ 96mph on Cooper Zeons. I was thinking about adding 3:73s. I would like to know what kind of power it is currently making and what else I should do to it.
Currently one of the O2 sensors is disconnected. What kind of impact would this have.
billfisher
1,296
huntsville, AL
Feb 18, 2006
  • Feb 18, 2006
welcome dude. save money and PI swap it, all the way. you are making more power than stock but not much more. get 4.30's. dyno it dude. or find a hp calculator.
03GTconv
49
Fort Worth
Feb 18, 2006
  • Feb 18, 2006
Not to much for the PI intake swap, ppl like foxlake say u can gain up to 85 Hp with the full conversion..but understand all that Hp is mainly your PI heads and Cam. your car bone stock puts around 160 to the wheels being that it is an automatic. The most i would say from this swap would be 10-20 HP but only a dyno can tell..good luck in that. U can purchase some PI heads for around 400.00 on ebay, and remember years 2001-2004 the PI heads were Romeo Heads (Aluminum) so try goin with those year heads to save for the weight. As for o2 sensor reconnect this as your Check Engine light will come on. Unless u run an o/r H or X pipe then u can buy a programmer to turn this off. U may cause your car to run rich or lean buy just keeping your 02 sensor unconnected.
stang_man_1
24
  • Feb 18, 2006
Thanks man. Im really not sure what has been done to the car. i bought it used and i don't know the previous owner. The reason the O2 sensor is disconnected is because the wiring is bad to grind on the ground since my car is lowered. it keeps shorting out and leaving me stranded. Any advice.
How much would a set of cams cost and where could i find them.
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
