98' Cobra clutch and fuel pump
aleborjas
610
hi i Have a 1998 cobra with stroker kit to 5.0, ported heads, stock cams, vortech 15 pounds of Boost, 42 injectors, vortech FMU, long tube headders, 2.5 X pipe, 3" cat back...
My cuestion is i need to change the clutch wich one should i use i thought of going with SPEC stage 3 or RAM Powergrip HD any other? (not centerforce)
The other thing is i have the stock fuel pump i whant to put double pumps wich pumps i should get? 2 190GPH or 2 255GPH??? and what brand? can i use 2 focus pumps? :shrug: remember my car has return line so the pumps are always on 12 volts...
Sounds like you are pushing around 550rwhp or so? I'd go with the McCleod clutch...It's one of the strongest clutches out there and a lot of 03/04 guys making big power that still have the T56 in are using...They aren't real cheap though...
