98 Drivers Window Problems
apats77
178
Watertown, MA
Just replaced the hinges on my drivers side door and now the window (all the way up) hits the top of the (not sure what to call it) window frame? With the window down the door lines line up perfectly and the door shuts almost like new. Before I bought the car the drivers side window was replaced by the dealer.
Im wondering if with the old crap hinges, when they replaced it they miss aligned it. Any help would be appreciated.
1fun281 that sounds like it could be the problem. Do you know where these stops are located?
They are inside the door panel at the very bottom left hand corner of the window take the panel off and move the window up and down and you will see what im talking about the stops will hit a piece bolted to the door and if theyre like mine they will move a little when they hit causing the window to go up too far
