You are correct on the brakes. The are not the 99-up front assembly.Two questions tho. #1 I was told that I could swap out the proportining valve inside the brass from a 94-95gt/v6 car and not need the adjustable prop valve. any truth? or would I have better results with the way you described? #2 what are the weather head adapters for?
I'm also not sure on the booster but i would think it would just make the pedal effort alot easier more than more stopping power. BUT could be wrong and have been before
Yeah. Because 96 up axles ate even wider than the 94-95 ones. I have a 94 rear end under my car, and I had to roll my fenders using 8in wheels and 245's.
Ok thanks guys!! So if I wanted too, I could buy a set of northcar brackets and use my fox 5 lug axles to make it basically a fox axle?
