99-04's engine/Auto tranny
  • Thread starter Thread starter Makdaddymac
  • Start date Start date Feb 25, 2010
M
Makdaddymac
323
orlando
Feb 25, 2010
  • Feb 25, 2010
hey all i am a 5.0 talk regular,
but I'm looking into getting a 99-04 mustang..I want a auto for this cause i have no intention of modding it, just want the mod motor exhaust note and some power.....but i was wondering what are the limits of the 2v gt motors and trannys if i were to slap on a supercharger on it nothing to serious just like 350-380whp??? i have a fox 5 speed with more intent to mod but i think the price of 99-04 gt autos are getting tempting...thx
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Feb 25, 2010
  • Feb 25, 2010
Well most people would agree on here that much more than about 430rwhp is starting to really push it for the stock blocks. The trannys im not so sure about but i know that ive never had a problem with mine and ive been pushing 375+rwhp for a few years now although its a 5 spd.
Now, there are plenty of exceptions on stangnet. Theres a couple guys around here pushing 475rwhp and even a few over the 500rwhp mark...including someone who just dynoed at 540ish i wanna say...all on the stock block
M
Makdaddymac
323
orlando
Feb 25, 2010
  • Feb 25, 2010
yeah my golas would not push the limits of the block. but im trying to see the input on the auto 4r70w trans i hope thats what in the 99-04gt!?!!?!?
D
Deleted member 38176
Feb 25, 2010
  • Feb 25, 2010
The 4R70W's are underestimated as far as their strength. They are tough trannies and will easily handle 400rwhp on a daily basis for quite a while.
Red35th
609
Houston, TX
Feb 25, 2010
  • Feb 25, 2010
I can second 4r70w's strength. I've been using a NX kit jetted at 100hp for years.
If you put a trans cooler on it, it'll last for a long time at 400hp. I'd imagine that's especially true if it's a centrifugal (less torque and smoother power band).
hotstang_46
481
Charlotte NC
Feb 25, 2010
  • Feb 25, 2010
It's strength may be ok but jeesh....it's behaviour clearly makes it the worst acting tranny in any car I've personally owned/ driven for any length of time. The wandering between gears is the worst. If you get it, at minimum do the JMOD, do a search, you'll probably find a ton of info, that will help.
ps...I'm one of those with big hp on a stock block. Just an FYI... If you ever wanted to upgrade that blower and go over 400-430+ meth will help that keep everything in one piece.
68stang351
850
9
39
Savoy TX
Feb 25, 2010
  • Feb 25, 2010
The way I've read is that the 4R70W means 4= 4 speed, R=rear wheel drive 70 = 700 ft/lbs torque capability, W= wide ratio.
They say it's a pretty tough trans. I read that explanation in one of the Mustang mags, they were swapping a 4R70W into a very heavily modded 05+ GT because it was stronger than the 5R55.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Feb 25, 2010
  • Feb 25, 2010
FWIIW, the 70 is not 700 ft/lbs of torque. It is 700 Nm which is about 516 ft/lbs.
If a 4R70W could support 700 ft/lbs, there would be a lot of happy hot rodders out there. Not to mention the market for upgraded transmissions would be much smaller.
The 5R55 is 550 Nm or 405 Ft/lbs.
D
Feb 25, 2010
  • Feb 25, 2010
WHAT???? So the autos in the 05+ cars can only handle around 400tq??
bhuff30
6,037
35
129
Olathe KS
Feb 25, 2010
#10
  • Feb 25, 2010
  • #10
So what is the torque rating of a C4?
scupking
1,186
Enfield, CT
Feb 25, 2010
#11
  • Feb 25, 2010
  • #11
+1 its a very strong tranny but you must do some things to make it fun and last a very log time.
1. tranny cooler
2. jmod
3. stall converter (3,000-3,200rpm stall)
4. 3.73 or 4.10 gears
5. SCT Xcal III tuner
If you do the above you will have a very fun auto mustang.
stang06girl
30
Southern California
Feb 25, 2010
#12
  • Feb 25, 2010
  • #12
If always read the code as ft-lbs, Where did you find out that it is in Nm?
D
Feb 25, 2010
#13
  • Feb 25, 2010
  • #13
Just did a little searching and found this:
4R75W is a torque upgrade from 4R70. The numbers in Ford's auto trans nomenclature refer to torque levels which can be accomodated, I believe on the downstream side of the torque converter (i.e., turbine side), in Newton-meters.
bhuff30
6,037
35
129
Olathe KS
Feb 26, 2010
#14
  • Feb 26, 2010
  • #14
I forgot about the multiplication effect of the torque converter. Normally, manual transmissions, like the T5, TR3650 and T45 have torque ratings between 300 and 340 ft*lbs, which isn't that much. So I was very surprised to see a torque rating of 700N*M (500 ft*lbs) on the automatic. However, you have to remember that the torque converter has a multiplying effect at very slow speeds. You can even get a 2x multiplication of torque if you slam on the gas from a dead stop. Keep that in mind when considering how well your transmission will handle the power.
stang06girl
30
Southern California
Feb 26, 2010
#15
  • Feb 26, 2010
  • #15
I guess it's a good thing my Nitto's don't hook worth a crap. At 520 RWHP and somewhere like 460 ft lb of torque I should have snapped the 5R55S in two by now.
Just to throw another tranny into the loop, thr 6R80W trans that they are putting in the 2011's (currently it's in the larger trucks and expeditions) might be worth looking into as well.
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
R
New Member, needs help with built '04 engine
  • rollo19
  • Aug 6, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 6, 2025
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
WTB: Procharger or Vortech Supercharger – 1996–1998 Mustang GT 4.6 2V – Budget $3,200
  • 96mustang.gt
  • Nov 20, 2025
  • Want to Buy
Want to Buy May 3, 2026
roblabsn95
R
