99 explorer upper and lower intake
bill302
2,131
alabama,gadsden
i have a 95 mustang GT see signature i have a chance to purchase a 99 5.0 explorer upper and lower intake with fuel rail and injectors will this intake bolt directly on to my 5.0 and what other parts will i need... thanks bill302
The upper and lower will bolt up with the use of an elbow. The injectors and fuel rail won't work.
99 explorer intake
Only the 96-early 97 Explorer intakes had the internal EGR passages like the 87-93 stock intakes if you need to stay with emissions checks. The later 97 up Explorer intakes do not have the internal EGR passages, but they are compatible with the 94-95 external EGR systems-BUT they have to be converted to a Fox throttle assy to work.
so i will need an elbow(sn95 throttle body adapter) to hook up my throttle body and c.a.i. and i can reuse the fuel rail and injectors that are on my intake in the car.why can't i use the fuel rail and injectors off the 99 explorer intake and egr will bolt right up without modification.... thanks.
back to the top i need info. on this subject, is this about the best and cheapest upgrade i can make with my stock heads and is it worth it? and will my stock fuel rail and injectors off my stang will fit onto explorer intake???? and i will need a elbo with a egr hookup right?
one of the first things i did to my car was the intake. its worth it. your stock rails and injectors will work. im pretty sure all the elbows have the egr hookup.
do i need to buy the explorer throttle body along with the upper&lower intake or is the factory throttle body in my stang the same one as explorer..... also is the lower intake different on explorer than the factory one on my stang.
You only need the upper and lower intake from the Explorer. Buy a elbow adaptor and use your stock throttle body. No, the GT Mustang lower will not work with the Explorer upper as they are not interchangable. Also, the throttle body from the Explorer will not work.
