9in Versailles in my 67?
afast93stang
1,407
North Texas
A friend of mine is considering selling his 9in Versailles with disk brakes and im thinking about buying it from him.
What's a fair price to offer?
It should be a bolt on part, correct?
  • Sponsors(?)
latamud
791
Tampa, FL
www.hubgarage.com
I sold one at the Ford swap meet rebuilt, Richmond 3.73 Trac Lok, new lines and hoses. $500. I picked it up for $125 out of the junk yard years ago. Guy a few aisles over was asking $900 for a rusty seized one. Swapping in an IRS and the 9 was getting in the way. So, depends on where, when and who is selling it. I've seen them average around $400 stock around here.
Wart
I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
408
NE Ohio
Isn't that a question.
I paid $300 for the entire car I got mine out of so I also got the 351W and C4.
And a local bone yard wanted $300 for just the rear minus calipers, rotors, and shields.
That would depend on your definition of bolt in.
I've seen people take housings where perch distance was off by an inch or more and because they could get the perch over the spring pin (because leaves without the axle flop around) and get the hardware cinched down they saw it as a bolt in. So you may need to relocate the perches.
There is the E-Brake, I'm pretty sure the cable wouldn't be a direct swap, though I'm pretty sure you can get a cable that would be a bolt it (Not like your doing this to a Mustang II).
You may need to get a larger volume master and install (a) residual pressure valve(s).
And finally brake bias. That can be handled by resizing brake components front and/or rear or installing an adjustable proportioning valve.
And depending on your level of anality, if your going from an 8" with 2 7/8 tubes tot he 9" with 3" tubes you may want to get different spring plates. I'm not sure about this one because it's been years (decades (ouch)) since I owned the 67 and 71.
96 DOHC Cobra
541
Cerritos, CA
Visit site
Around here, a complete stock one in all good useable condition goes for about $500. If it has a traction lok, add $200-300 depending on the ratio. Maake sure it's all there and all good. Parts for these are a little hard to find and expensive. Also, be sure to look into the E-brake issue. Many people report problems getting the E-brake to work properly.
tx65coupe
I have one in my 65 that I got about a year and a half ago for 500 bucks. It was complete but needed to be rebuilt. It now sports better gears and traction lock.
The only way it is worth 1000 bucks is if it is rebuilt with new bearings better gears and traction lock.
It also must be complete with all of the brake parts and dust shields and emergency brake parts.
2+2GT
Well-Known Member
Apr 25, 2009
3,333
10
59
Southeastern Pennsylvania
After talking to my friend a bit more he is wanting $1000 for it. Thats not in my budget right now.
For that kind of money Currie would send you a 4-pinion Traction-Lok™ in a carrier with your choice of gears, ready to bolt into your existing housing. With the right tools, a couple of hours and you're off and running.
bnickel
5,640
51
lubbock, texas
Visit site
i sold mine a couple years ago for right around $1000 but it was rebuilt with all new bearings and seals, rebuilt calipers, new rotors and a 3.70 geared open center section also with new bearings and seals, it was also painted and detailed correctly for installation into a mustang as well. hell of a lot cheaper than buying a currie rear even if you had a trac-lok installed.
Thread starter Similar threads Forum Replies Date
ZeroFoxGiven 9in rear end w/disc brakes [Parking Brake] 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
bluelx347 SOLD Moser Ford 9in 31 Spline Axles Drivetrain Parts 0
B Rear End Upgrade To 9in 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
A Best tire size for a 9in. rim? SN95 4.6L Mustang Tech 20
6 I need help on a 9in seal? Classic Mustang Specific Tech 11
Grantiz84 Alright the 9in is in! (pics) 1965 - 1973 Classic Mustangs -General/Talk- 8
T 9in rearend disassembly question Classic Mustang Specific Tech 19
0 245's on 9in rim? 1996 - 2004 SN95 Mustang -General/Talk- 9
blkstangman88 good 9in rear axle? Fox 5.0 Mustang Tech 3
M 57-59 Ranchero 9in. Axle compatability? Classic Mustang Specific Tech 1
68RustBucket need a 9in. for the new motor Classic Mustang Specific Tech 9
TrickStang37 Replacing 6cyl rear end for 9in Classic Mustang Specific Tech 5
S anybody put a 9in rear in an original straight 6 car? Classic Mustang Specific Tech 7
B I have 69 mustang 302, 3speed, with 9in rearend, whats the best performance gear? Classic Mustang Specific Tech 5
6 narrowing 9in rearend Classic Mustang Specific Tech 6
ADRENLN 17in by 9in with 275 all around SN95 4.6L Mustang Tech 0
1 Driveshaft U-bolts on ford 9in? Classic Mustang Specific Tech 5
03-s281 Will 295/35's fit a 9in rim?? SN95 4.6L Mustang Tech 4
1 What spline axal in 1973 9in mustang rear? Classic Mustang Specific Tech 2
R Is Versaille rear a bad idea? Classic Mustang Specific Tech 5
PM 65 Versailles Rear End - caliper bracket loose - detailed part drawing?! Classic Mustang Specific Tech 8
tx65coupe Versailles Rear and Shock Clearance Classic Mustang Specific Tech 7
tx65coupe Lincoln Versailles Parking Brake Classic Mustang Specific Tech 12
66sprint6 Complete Versailles 9" Disc Brake rearend Drivetrain Parts 4
K 77 Versailles rear install tips? Classic Mustang Specific Tech 11
H versailles rear end stuff Drivetrain Parts 0
H exploder brakes on versailles rear end? Classic Mustang Specific Tech 8
H new versailles rear end parts Drivetrain Parts 9
R Versailles bearing design, rotor flange thickness and tire rub Classic Mustang Specific Tech 3
tx65coupe Sway Bar Fitment With Versailles Rear End Classic Mustang Specific Tech 8
tx65coupe Versailles Axle Re-Install Classic Mustang Specific Tech 13
S Stripping a Versailles. What to keep? Classic Mustang Specific Tech 6
tx65coupe 65 With Versailles Rear and Traction Master Bars Classic Mustang Specific Tech 14
M Need help on choosing a limited slip for my versailles Classic Mustang Specific Tech 6
tx65coupe Versailles Rear End & T-5 Setup Classic Mustang Specific Tech 13
tx65coupe 65 Stang With Versailles Brakes Classic Mustang Specific Tech 10
D Lincoln Versailles 9" for sale Engine and Power Adder 4
nemlio65 versailles rearend problems with fitment Classic Mustang Specific Tech 19
downpiped versailles rear..which shock plates? Classic Mustang Specific Tech 2
golf4283 Versailles Disc brake options Classic Mustang Specific Tech 13
nemlio65 Versailles Rear End Assembly Classic Mustang Specific Tech 14
1 Versailles rear a bolt-in for a '65? Classic Mustang Specific Tech 25
6 Versailles rear with 275 tires back space? Classic Mustang Specific Tech 5
B Versailles EFI? Classic Mustang Specific Tech 2
3 versailles rear end Classic Mustang Specific Tech 2
nemlio65 versailles rear end tire fit ???? Classic Mustang Specific Tech 2
3 lincoln versailles rear end Classic Mustang Specific Tech 8
T Lincoln Versailles 9 inch Rear Disc Rearend Engine and Power Adder 0
T Lincoln Versailles 9 inch Rear Disc Rearend Engine and Power Adder 4
MO351 Versailles 9" in a 73 Mach 1 Classic Mustang Specific Tech 4
