A/C blowing defrost
  • Thread starter Thread starter 70/04mach1
  • Start date Start date Jul 20, 2025
70/04mach1
Missouri
Jul 20, 2025
  • Jul 20, 2025
I can select defrost, floor, or both and I have air. Heat blows hot and a/c blows cold. When I select vents I have nothing and it goes to defrost. I have checked all lines!!!! The black line coming through firewall is good. It is pulling vac at the tree behind the dash. I have checked all lines behind the radio. Yellow line is pulling vac. All lines are connected and not loose. What next????
Admin Dude
Jan 4, 1985
43,563
21,732
234
Box behind Walmart
Jul 20, 2025
  • Jul 20, 2025
Blend door actuator?
Reactions: stormsedge
70/04mach1
Missouri
Jul 20, 2025
  • Jul 20, 2025
Do you happen to have a part # and a description? Thank you.
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,239
2,946
224
Vass, NC
Jul 21, 2025
  • Jul 21, 2025
I'm not sure how alike the SN95 A/C is to a fox, but so far what you've described sounds like a fox's default when it loses vacuum (defrost & floor, I believe). So, maybe your vacuum logic is close to or the same as ours:
Admin Dude
Jan 4, 1985
43,563
21,732
234
Box behind Walmart
Jul 21, 2025
  • Jul 21, 2025
You will need to verify this part number:
AR33‑19E616‑BB and referred to as "Heater Regulator Engine" is what I've found for the 2004 Mustang GT.
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Resolved No air to the vents, only air to the defrost and feet
  • Dontknowchit
  • Mar 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
Dontknowchit
N
Complex changes need help
  • nomoremasks
  • Sep 15, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 15, 2025
nomoremasks
N
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
