  • 2.3L (N/A & Turbo) Tech
A/C clutch coil
  • Thread starter Thread starter Ponycar
  • Start date Start date May 7, 2007
P
Ponycar
90
Virginia Beach VA
May 7, 2007
  • May 7, 2007
Have a 93 vert.. the a/c compressor will not come on. I have 12v to it when it is turned on. also jumpered out the low pressure switch. The clutch is not locked up either...Is there any way to bench test the clutch coil ???
P
Ponycar
90
Virginia Beach VA
May 10, 2007
  • May 10, 2007
guess nobody knows. ok- anybody with a 91-93 with a/c take a mulitmeter and pop off the power plug from the compressor and check the resistance of the clutch coil for a comparative reading??????????
goland55
2,847
New Bedford, MA
May 10, 2007
  • May 10, 2007
If you unplug the clutch coil and put 12v to one terminal and ground the other terminal it should lock up. If it doesn't, the clutch is bad.
D
1999 G/T 4.6 A/C clutch not engaging.
  • David B.
  • Apr 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 8, 2025
David B.
D
W
a/c compressors i d
  • waxman
  • Jan 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Did I fry something messing with my ignition?
  • 85gtCOBRA
  • Oct 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 15, 2025
85gtCOBRA
New guy- first Stang- I love it !!
  • smid333
  • Mar 22, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 23, 2026
smid333
U
Knowledge Sought
  • USMCE3ROFP
  • Dec 6, 2025
  • Other Auto Tech
Other Auto Tech Dec 6, 2025
USMCE3ROFP
U
