A/c clutch replacement
  • Thread starter Thread starter RsStanG1987
  • Start date Start date Aug 28, 2005
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Aug 28, 2005
  • Aug 28, 2005
What is needed to do this besides just the clutch do they make a kit? Can i do it wile the compressor is still hooked up. Any help = good help
D
Daggar
3,902
  • Aug 28, 2005
Yes... you need not remove the compressor or disharge the system. Pull the serpentine belt. Pull the fan shroud and possibly the radiator depending on how much room you have with the radiator you have installed. Remove the A/C pulley then use a set of reversible snap ring pliers to take the snap ring off that's holding the clutch assy in place. Put the new one on, and put whatever you had to take apart back on and whola!
Shouldn't take you more than an hour or so. Make sure you have the snap ring fully seated.
RsStanG1987
569
9
79
Dupont PA
Aug 28, 2005
  • Aug 28, 2005
no brushes or anything inside the pump need to be replaced...
PuterAmI
513
Madison, Alabama
Aug 29, 2005
  • Aug 29, 2005
Or, pull the compressor. Just a few bolts and you can swing it so that one would not have to take out the radiator.
No, no brushes or such. It uses a field coil to energize.
D
Daggar
3,902
  • Aug 29, 2005
Hmmmm.... what is the going rate of anti-freeze vs. R-12 these days?
Edit: NM... I get what you're saying. You'r talking about removing just the bracket mount bolts and not the service lines.
tripwhite93
  • Aug 29, 2005
Remember to measure air gap between A/C clutch and A/C clutch pulley It should between 0.014-0.033 inch. The shams come with the new clutch.
PuterAmI
513
Madison, Alabama
Aug 29, 2005
  • Aug 29, 2005
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
W
a/c compressors i d
  • waxman
  • Jan 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
