If it anything like the Ford Racing kit be sure your relocating your PS pump where the AC compressor was. Line the two holes up on the lefthand side of the bracket (passengerside) with the Studs on the water pump and mount the PS pump behind the bracket. Slide the two long bolts through the two holes on the righthand (drivers side) of the bracket and find the holes where the AC support was on the heads. You should be all set. If trick flow sells a totally diff kit then .... good luck
