Well my A/C was working, I parked the car and when I got back in it about 30 mins later, the A/C wouldn't turn on, just blew normal air through the vents. So here is where I am at, and hopefully someone can help point me in the direction to go.
I have changed the low pressure cycle switch. When I jump the low pressure cycle switch, the engine revs higher, but the a/c clutch does not engage. When I remove the jumper the engine rev lowers. I have also checked the fuses inside the car by the driver door and the fuse box under the hood. The fuses are good. The system is also charged properly, as verified by a set of a/c gauges.
Any help you can provide is GREATLY appreciated.
Thanks!
Thanks!
