A/C Low Side Service Port - Location
Treachery
148
Which of the 2 service ports is the Low Side port?
See attached picture.
The port on the A/C compressor, on the right, has a slightly larger diameter than the port on the left.
Thanks.
The one on the compressor is the low side (hense the "S" on the compressor housing). The A/C fittings that you are charging/servicing the system with has the proper fittings on them already so you cant mix them up anyways.
