  • SN95 4.6L Mustang Tech
A/C Malfunction?
  • Thread starter Thread starter DKVL
  • Start date Start date Apr 6, 2009
D
DKVL
113
  • Apr 6, 2009
My AC is not working. The fan is on, but the air is not cold. I have changed it into different settings and the air does not cool at all.
The heater works fine.
I had my freons recharged just before november and it worked without any problems until today.
Where is the AC belt, if any?
What can be causing this malfunction?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Apr 7, 2009
  • Apr 7, 2009
The AC is driven by the main accessory belt. Check to ensure you have a full charge, since it could still have leaked out somewhere. If your charge is sufficient, jumper the harness for the low pressure sensor on the accumulator and see if the compressor runs. If it does, you need the new sensor. It's like $24 at Napa
evil281
276
Arizona
Apr 7, 2009
  • Apr 7, 2009
does the a/c compressor kick on and off a bunch when u have max a/c on?
D
DKVL
113
  • Apr 7, 2009
The compressor use to kick on and off a bunch of times before when the AC was on. That was why i had my freons recharged.
Now, the compressor doesn't appear to be coming on at all.
I am not sure why this is happening? is my compressor dead?
evil281
276
Arizona
Apr 7, 2009
  • Apr 7, 2009
it may have been locked up from drying out, best take it to a shop and actually watch what they r doing, dnt let em screw u , i got two opinions before i replaced my compressor, it was kicking on and off, freon leak, and the the main seal was toast
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
M
cooling fan not turning on, but does when ac is on or when coolant temp is jumped or unplugged.
  • Mycarhatesme
  • Mar 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 12, 2026
A
Strange AC issue
  • Adanesahde
  • May 3, 2025
SN95 4.6L Mustang Tech May 3, 2025
Mcmahst
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
J
V-6 thermostatically controlled cooling fan - on when cold - new behaviour
  • jacekk
  • Oct 1, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 1, 2025
jacekk
J
