Nope, sure doesn't. Sounds like a vacuum leak. If you just looped off the heater core & noticed this issue, more than likely the vacuum line that runs inside to control the selector position was accidentaly broken or disconnected. Start there first & if you don't find anything, look under the dash at the multi-colored vacuum lines to make sure they are all connected.
