  • 1994 - 1995 Specific Tech
A/C Problem on 94 5.0
  • Thread starter Thread starter NC_Mustang_Man
  • Start date Start date May 28, 2007
N
NC_Mustang_Man
23
  • May 28, 2007
Bought the car a couple weeks ago, decided to charge the ac today. Recovered it, pulled a vaccum, only recovered .50lb so I put another 1.50lb in it. Compressor spins freely by hand. Well just to get to the point, AC is charged, and not working. Tried jumping the connector at the low pressure switch, and that didnt't fix it, well come to find out I check the power at the compressor and there is not power to the compressor, I dont have access to Alldata anymore seeing as I had a work related injury so I can't pull up any diagrams or anything. Just wondering if you any of you guys have had this problem occur with your SN95, this is the first one I have owned, used to foxbodies and f-body cars. But anyways any opinions or ideas would help.
Thanks
HISSIN50
34
129
May 28, 2007
  • May 28, 2007
Do you have power egressing the LPCS? If so but it doesnt make it to the AC coil, check the output voltage at the WOT Relay (in the CCRM). There's a decent chance that's where the issue lies if the system is up to pressure, etc.
(BTW, did you jump the LPCS in order to charge the system? You should have had to. If so, was the clutch engaging?).
Good luck.
C
chuck943
262
north carolina
May 28, 2007
  • May 28, 2007
Voltage come from fuse 5(15 amp) IP fuse box thru ac controls to low pressure cycling switch on P wire thru switch on DB/Y wire,if that switch is ok, then it goes to the high pressure switch and comes out on the DG/O wire to CCRM pin 21 ( if pressures are to high on high pressure switch PCM will ground the PK/LB to the BLK to disable this. It then leaves CCRM on the BK/Y wire (pin 23) of CCRM and goes to AC clutch,ground side of AC coil goes back to CCRM on BLK wire to pin 16.
N
NC_Mustang_Man
23
  • May 28, 2007
I will try to take what was said and work through the wiring to see what the situation at hand is, the clutch is not engaging at all, spins freely by hand. Doesn't have power to regardless, even if I jumper it, still not power to compressor. I have traced the wires back to a plug in right under the fuse box in the engine bay and the other end of the connector coming to the compressor doesn't have power on it either.
N
NC_Mustang_Man
23
  • May 29, 2007
I feel stupid, I cant located the WOT relay, someone told me that it was near the passenger side shock tower, correct? I have a haynes manual but its confusing me more than helping me.
HISSIN50
34
129
May 29, 2007
  • May 29, 2007
Chuck and I both referenced it. It's in the CCRM.
A WOT relay on the passenger shock tower area is true.......... For a fox III.
See Chuck's informative post to diagnose the WOT relay. He tells you which are the in and out terminals for power through the WOT relay.
After you see that (it's an easy place to start), you know which direction to go to find a fix.
Good luck.
N
NC_Mustang_Man
23
  • May 29, 2007
In order to acces the WOT relay do I have to take the black box apart? No power a pin 21 on the connector.
N
NC_Mustang_Man
23
  • May 29, 2007
Shouldn't I have voltage at the high pressure switch connector? Cause there is no power coming into the connector.
C
chuck943
262
north carolina
May 29, 2007
  • May 29, 2007
yes it should be coming from the low pressure cycling switch on the DB/Y wire then leaving on the DG/O
N
NC_Mustang_Man
23
#10
  • May 29, 2007
  • #10
I have no voltage at the high pressure switch.... I assume is a problem between the low pressure switch and the high pressure switch, reckon it some bad wiring...could it be anything else?
C
chuck943
262
north carolina
May 29, 2007
#11
  • May 29, 2007
  • #11
u have it leaving the low pressure switch?
N
NC_Mustang_Man
23
#12
  • May 29, 2007
  • #12
power at the connector that plugs into the lower pressure switch, no power at the connector to the high pressure switch.....like I mentioned Im not getting any power to the CCRM for the AC circuit, so for some odd reason Im not getting power to there
C
chuck943
262
north carolina
May 29, 2007
#13
  • May 29, 2007
  • #13
overlay the DB/Y wire from low pressure switch to high pressure switch
N
NC_Mustang_Man
23
#14
  • May 29, 2007
  • #14
Where are you at in NC, I am myself, I am fair from an AC repair, Im only good with building a motor, or turn wrenches, not to much of an electircal man. What do you mean by overlay? I dont want to screw nothing up, haha.
C
chuck943
262
north carolina
May 29, 2007
#15
  • May 29, 2007
  • #15
archdale.
run a new wire from low pressure switch to high pressure switch DB/Y wire
N
NC_Mustang_Man
23
#16
  • May 29, 2007
  • #16
ok so if it works after that, that means I have a wiring problem somewhere in between those two, correct?
C
chuck943
262
north carolina
May 29, 2007
#17
  • May 29, 2007
  • #17
check private messgae
N
NC_Mustang_Man
23
#18
  • May 29, 2007
  • #18
sent you one back
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
J
2003, 3.8l with air conditioning problems
  • Jimb0z '03
  • Nov 3, 2024
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2024
Jimb0z '03
J
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Electrical 89 fox AC help please
  • Fast89GWILL
  • Dec 5, 2024
Fox 5.0 Mustang Tech Dec 18, 2024
Mindseye007
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
