Jrichker is right-on. Sometimes just grabbing the relay and socket will make the clutch engage for a second (till it moves an iota and kicks off because of vulcanized wiring).
If the relay has power leaving the normally closed terminal, disconnect the clutch connector and relay socket and check continuity between both ends of the blk/yellow wire. If ok, ohm out the clutch's ground.
