A/C Problems
See what the pressure is like at the low side. Both when working good and when not. Mine cycled on and off constantly when it was low.... I think it does this to help keep from destroying itself. Not good for it to run while the charge is low, either.
95stalliongt, I havent even tried to fix my a/c, it sux.
However, you have the mods as I do, I was just curious, since Im getting a Transgo kit next week, are you happy with it? Did it make a difference?
Thanx for the time.
Yeah, get a pressure gauge from autozone and see how much pressure you have with the compressor running on the low side. Low side is the fitting at the d-side line that runs next to the upper intake. You will need to loosen your STB for access.
And if you are low on charge, you need to find the leak and fix it. Get some r-134a that has the UV leak detector added already, and use a blacklight to find the leak. If you can't find it the first day, wait a couple and try it again. The leak may be slow and needs to reveal itself.
Once you find the leak, just repair it with silver solder.
Scott
