  • SN95 4.6L Mustang Tech
A/C Question
  • Thread starter Thread starter RedLine01
  • Start date Start date May 24, 2005
R
RedLine01
148
MaComb Twp., MI.
May 24, 2005
  • May 24, 2005
A/C Question with pic
Can someone tell me what type of fitting this is and how do I get the two pieces seperated?
Thanks
R
RedLine01
148
MaComb Twp., MI.
May 24, 2005
  • May 24, 2005
Ttt
5.0's 4 ever
The #1 Stunna
5,794
Orlando, FL
May 24, 2005
  • May 24, 2005
That is a spring lock coupler, you need spring lock tools to seperate the lines correctly. Places like autozone and other stores have sets of around 5 different size plastic ones for disconnecting a/c and fuel lines.
From that pic its looks like you really messed up the fitting at the accumulator and that ac line. If that is the case you will have to get new ones.
R
RedLine01
148
MaComb Twp., MI.
May 24, 2005
  • May 24, 2005
Thanks for the reply. I already have the reciever but im hoping the other side is ok. I orginally tried jb cold weld qand that didnt work so using the dremel I cleaned those pieces off. Ill check autozone tom.
Thanks again
Red mustang Gt 46
601
Good ol' Maryland
May 25, 2005
  • May 25, 2005
Yup, that spring coupling is TOAST, should have sought help before it was seperated. I've seen a poo load of people do this with the fuel lines also...a costly mistake.
ts1lmayb
67
Alabama
May 25, 2005
  • May 25, 2005
damn man! that sucks. I'm going through the same problem... sorta. just gotta go get the disconnect tool, replace the line, and recharge the system.
sucks man........
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
May 25, 2005
  • May 25, 2005
Thanks
HOLY ****!!!!!!!!!!!! what did you do to that fitting. it's a spring lock fitting. you need a/c line removal tools too seperate them.
BTW you need a new accumulator now and the line running from the accumulator to the manifold line.
R
RedLine01
148
MaComb Twp., MI.
May 25, 2005
  • May 25, 2005
I did a fine job on that when I was pulling the motor
GTvert01
636
West Plains, MO
May 25, 2005
  • May 25, 2005
lol, you're going to kick yourself when you see how easy they come apart with the right tools.
R
RedLine01
148
MaComb Twp., MI.
May 25, 2005
#10
  • May 25, 2005
  • #10
Ill tell you what, that was one of the "easy" things Ive done to the car. The new accumulator had a longer neck on the side going to the manifold, unlike the orginal utilizes a short piece between the two so I did not have to replace the hose line. Everything is back together and running good.
Thanks for all the replies
identifying smog/fuel part on 1998 GT
  • dochawk
  • Jun 18, 2026
SN95 4.6L Mustang Tech Jun 30, 2026
J
Can i buy this part seperately??
  • jacobh112
  • Jun 3, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 3, 2026
R
Electrical Unknown wiring harness
  • Rockobrews
  • Jun 14, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 16, 2026
Rockobrews
R
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
D
Progress Thread Today in the shed........
  • Don7Up
  • May 5, 2026
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 8:02 PM
DadLife0724
