I charged my system with freeze 12 and I got it working however it is inconsistent,it will blow cold down to 40 deg at the vent but if I give it gas, a little above idle ,the clutch cycles off and then back on and the temp shoots up to allmost 50 deg.If I jump the switch on the receiver it blows nice and cold for as long as it is jumped.I only have one of those pen type gauges ,it says im getting around 27 psi on the low side.Does the switch need to be swapped out if im running 134a or in my case freeze 12.or could it be not enough freon.
