  • SN95 4.6L Mustang Tech
A/C question
  • Thread starter Thread starter Pennywise2
  • Start date Start date May 16, 2006
P
Pennywise2
Banned
May 16, 2006
1,379
  • May 16, 2006
My A/C compressor is ten years old and I have a hole in my seal of my A/C compressor and the A/C charge leaks. The A/C doesn't come out cold but, luke warm out of the A/C vents. Guys should I get a brand new A/C compressor or get the one I have now rebuild? What's the best bet?
P
Pennywise2
Banned
May 16, 2006
1,379
  • May 16, 2006
Anyone please!
P
Pennywise2
Banned
May 16, 2006
1,379
  • May 17, 2006
Bump...for the night crew. Comments anyone?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
May 17, 2006
  • May 17, 2006
do you know where the leak is? is it one of the green rubber seals on the back of the compressor where the manifold line plugs in? if so you can get those at most part stores, fix the leak and have somebody evac and recharge the system ( you need to have the evac done, if this is not done you will have problems)
IF you had it recharged properly and it's still warm it could be things other than the compressor a orifice tube is one thing that can cause that problem.
so here is what you need to do.
1. fix known leak
2. recharge system properly ( no little cans of r-134.. you need to have evac and vacuum pulled on the system)
3. if cold enjoy your a/c and go to step 4 if not cold skip step 4 for now and go to step 5
4. have beer(s)
5. hook up guagues to a/c high and low sides and get me presure readings, also I need to know the duty cycle of the /c compresor.. as in how often does it cycle on for then how long it stays off for, and I need to knwo the weather conditions ( temp, humidity)
if I happen to miss your post PM me to remind me.
P
Pennywise2
Banned
May 16, 2006
1,379
  • May 17, 2006
The leak is coming from the bottom of the A/C compressor.It leaks
the A/C charge.I had it looked at they told me that the seal on the compressor has a hole in the it and I would be better off just buying a new
A/C compressor instead of rebuilding the old one.I just want a second opnion.
Thanks for the reply Mike!
jstreet0204
939
Winston Salem, NC
May 17, 2006
  • May 17, 2006
Some ford compressors you can replace the front shaft seal on. I know I just replaced the one on my bronco, even though every parts store I went to told me I'd have to get a whole new compressor.
P
Pennywise2
Banned
May 16, 2006
1,379
  • May 17, 2006
Thanks alot for the info I just ordered a brand new A/C compressor from Ford because the ten year old one I have now is starting to make a wine
sound when I turn on the A/C. I belive my current A/C compressor just
bit the dust.
Mike97gt
it doe snot
10,633
May 17, 2006
  • May 17, 2006
cool, well hopefully it's fixed.
P
Pennywise2
Banned
May 16, 2006
1,379
  • May 17, 2006
Yes I hope it's fixed after all this.I need a beer!
Thanks for your great info again Mike.
Mike97gt
it doe snot
10,633
May 18, 2006
#10
  • May 18, 2006
  • #10
no problem
jstreet0204
939
Winston Salem, NC
May 18, 2006
#11
  • May 18, 2006
  • #11
Just remember, you can't just bolt it on and fill it with antifreeze. Unless you have a vacuum pump and manifold guages, you'll have to take it somewhere to recharge the system.
Mike97gt
it doe snot
10,633
May 18, 2006
#12
  • May 18, 2006
  • #12
this is very important and you will see in my other posts in this thread I said no little cans of r-134, take it to somebody to evac the system and refill it properly.
jstreet0204
939
Winston Salem, NC
May 18, 2006
#13
  • May 18, 2006
  • #13
svttech76 said:
+1
Well, I use the little cans, but I have an air compressor that I can swap the valve on to make it pump, and a set of manifold guages. I just don't have access to the big drum of r134
M
MikeyV
#14
  • May 18, 2006
  • #14
QUESTION???
Sometimes, (most of the time) when I turn the knob to A/C, the ompressor clicks on 3-5 times. I'm used to 1 click.
Now, I just had this car at Ford to get the compressor re-charged (had a few bad o-rings) And the A/C blows freezing air.
Does anyone elses cars click the compressor on more than once (well, on/off etc)?
P
Pennywise2
Banned
May 16, 2006
1,379
#15
  • May 18, 2006
  • #15
svttech76 said:
+1
Mike97gt
it doe snot
10,633
May 18, 2006
#16
  • May 18, 2006
  • #16
that will work, but not many people on here own a set of manifold guages or the pump.
P
Pennywise2
Banned
May 16, 2006
1,379
#17
  • May 18, 2006
  • #17
Mike do you have to evac the system if there is no r-134 in the system
because my A/C right now only pushes out warm to hot air?
Mike97gt
it doe snot
10,633
May 18, 2006
#18
  • May 18, 2006
  • #18
yes to get a proper charge you need to evac the system anytime it's been opened, then pull a vacuum on it and fill into the vacumm. this really should be done by a professional. if it was cold and not hot again you problally have a leak.
sgarlic
3,085
May 19, 2006
#19
  • May 19, 2006
  • #19
You can get this pump if you have access to an air compressor http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92475 , then just bring it somewhere and have them recharge it.. might save you 30 or 40 bucks. Most places around here want ~35 bucks just to vacuum the system, then another 50 for the time to rechage, plus like 15 bucks per pound of refrigerant.
P
Pennywise2
Banned
May 16, 2006
1,379
#20
  • May 19, 2006
  • #20
Thanks for the imput guys you are a big help.
J
Mustang 1968 coupé restoration hvac
  • JackStang68
  • Mar 3, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
zookeeper
Engine A/C QUESTION
  • Mindseye007
  • Jun 5, 2025
  • 2 3 4
3K
Fox 5.0 Mustang Tech Jun 22, 2026
nicholase
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
