Got a 2000 GT with a strange A/C issue. Here's what has happened:
A month or two back, the compressor seal (front) started leaking and let enough oil out to cause the clutch to burn. Compressor was replaced, system evacuated, and re-charged and it ran fine until this past weekend.
A week plus ago, the intake manifold water passage decided to let go. Before you ask, no extended warranty, the car was originally bought 7/17/00, and it failed about a week after 7/17. A call to Ford got "sorry, but the class-action extended the warranty to 7 years, and we do not make any exceptions." Bought a new intake with an aluminum front water crossover and installed it. Seemed to run fine. Decided to run it up (RPM-wise) on an on-ramp, and a near-redline shift saw the A/C shut off and not come back on. Blower was ok, but the compressor was off. Started to trouble-shoot.
Checked the fuse, voltage to the cycling switch, through the high-pressure cutoff switch, and eventually found the relay control module in the right front fender-well. Verified that we had +12 volts to there as the schematic showed. I played with this relay module a while and discovered that the A/C compressor relay is normally closed, but the PCM can send a 12-volt signal to open the relay when it thinks that the A/C should be disabled (presumably at WOT, and some other as yet unknown conditions). I then verified that this signal was on all the time (pink/yellow or pink/blue wire, I don't remember which). I cut the wire and bam, the A/C now worked fine, except that when cranking the motor the compressor stayed on since the computer could not disengage the clutch. I then re-spliced the wire and things mysteriously worked just fine for a few days.
Today, we notice that that compressor is cycling on/off for no apparent reason and is not cooling. Guages show normal pressures a and the cycling switch is on all the time, so again the computer is turning the compressor off for unknown reasons.
My question is this: what conditions could cause the PCM to think "A/C needs to be off" when there is no apparent running problems. This happens whether there is plenty of cool air (or even a mist) going thru the condensor to make sure the pressure is not too high, etc. Idle seems normal unless the A/C starts going nuts, then when the clutch is engaged, the idle will drop way low, the computer will speed it up via the IAC, and then off it goes again...
If I cut the computer control to disengage the clutch, all seems normal.
The main point is that this started after a quick visit to 5800 RPM or so. There are no leaks, no nothing. I had seen a reference to a power steering pressure switch that could cause the PCM to shut the A/C off, but I can't find such a switch, and the MIL light is not on and an OBDII scanner shows no stored trouble codes of any kind.
Any ideas? BTW anybody have any idea why Ford decided to combine the A/C compressor relay, the fuel pump relay, etc, into one module that sells for over a hundred bucks on the net, while they still have a bank of 5 normal relays for things like the radiator fan, wipers, etc?
