A/c With Pro Charger.
BigK22
26
Hey guys,gonna be putting a/c back in my 93 gt. Any problems running a/c lines with supercharger . Any modification to lines needed. Running procharger system. Thanks
Procharger kit was designed to work with the AC installed . I don't really see an issue either being the blower is driver side mount and your AC lines all run to the pass side .
Reactions: 1 user
There is one that runs from the pump to the passenger side but my understanding is that is not an issue, too?
Maybe?
:doh: need to brush up on my reading
Pay no attention to the dip-stick tapping this keyboard.
Reactions: 1 user
Maybe?
Shouldn't be the blower sits on the driver side where the battery would almost be and the AC Comp sits in its regular spot . The one that returns from his pass side goes up by the distributor the way if I am not mistaken
The power steering pump has to be rotated. Only loosen mounting bolts, rotate a little & re-tightened.
Battery tray goes to passenger side same as 4 cylinder; one edge needs to be trimmed off. Then needs longer positive battery cable to starter relay.
Reactions: 1 user
