  • 2005 - 2009 Specific Tech
A couple questions (intake, exhaust, flash)
  • Thread starter Thread starter dpk136
  • Start date Start date Jun 20, 2007
D
dpk136
  • Jun 20, 2007
I have a 07 GT with a 3.55 rear and a Shaker Scoop. I was wondering what I can do to mod this (keeping the warranty and not blowing a ton of money). I read somewhere that i can put a cold air intake on this with the shaker scoop. Which ones would you guys suggest. Also, I was looking at the pypes exhaust midpipes system. How much HP am i looking at with these mods and will it be a problem that this is a Virginia car (emissions).
Also, what is involved with an engine flash. Do I have to take this to someone? Should I have had this done when the Shaker was installed (installed at dealer when purchased)
Thanks for any info that you guys may have.
David
Casey4s
147
Woodbridge, VA
Sep 2, 2007
  • Sep 2, 2007
I have an '05 GT with the CDC Shaker and a K&N Cold Air intake. K&N Says that no flash is needed and my car does run fine without flashing, but I also use a Predator and have a performance tune in my car. (Also a Va. Car)
To direct the cold air from my shaker to the aftermarket K&N intake I had to fabricate a few things but it was no really big deal. I have a series of before, during and after pics of my Shaker install, and the fabrication / modifications I made to make the shaker very functional.
Unfortunatly I have only figured out how to load one thumbnail sized photo at a time at this forum. If you email me I would be happy to send them, to you if you're interested.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 2, 2007
  • Sep 2, 2007
Air filter is looking a little dirty there Casey.
Casey4s
147
Woodbridge, VA
Sep 2, 2007
  • Sep 2, 2007
Actually I just serviced it with the K&N kit, it is really clean a s a whistle even though it might not look it in the photo.
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
Sep 3, 2007
  • Sep 3, 2007
dpk136, the exhaust will not net much power increase, but will give alot of sound. The only ways to add decent power is by changing to an O/R midpipe(hi flow midpipes will add sound, keep you emissions legal, but only add a few horsepower as the stock one flows pretty well)and/or ditching the factory exhaust manifolds.
A tuner will fix you up pretty nicely. I don't believe you needed a retune after the shaker install as it still flows through the stock air box and MAF sensor. If you get a CAI kit, get the tuner at the same time. That can net you in the neighborhood of 30 RWHP.
kooldawg6
Aug 31, 2006
1,679
Central VA
Sep 3, 2007
  • Sep 3, 2007
Casey4s said:
I have an '05 GT(Also a Va. Car)
You're just up/down the road from me here at work. Just off Rt1 near Lindsay Chevy.
Casey4s
147
Woodbridge, VA
Sep 3, 2007
  • Sep 3, 2007
No kidding... I am on Cannon Bluff Dr. on the edge of 22192...
Where do you work..?
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Sep 3, 2007
  • Sep 3, 2007
kool said NEAR a chevy dealer....
Casey4s
147
Woodbridge, VA
Sep 3, 2007
  • Sep 3, 2007
My Post is now corrected... DOH!!!!
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
2005 - 2009 Specific Tech Today at 5:19 PM
manicmechanic007
P
Electrical 1988 GT Wrong Cluster- causing electrical issues?
  • pindude80
  • May 6, 2025
Fox 5.0 Mustang Tech May 6, 2025
pindude80
P
