Maybe I am up too late. But I had a crazy idea while reading here.
I have read about people removing the spare tire well and making a flat trunk floor. So far so good, I would be carrying a larger spare than would fit in there anyway.
Also read about using a fuel cell and centering it for easier exhaust. That is where my first idea came into being. I was thinking why not just use the stock tank and center it? Well, after seeing pictures of it the top isn't flat, so I can see that being a serious issue.
So my next idea is what about a tank out of another car? One that does have a flatish top.
So my real question is has anyone else thought about doing this and if so do you have any tanks in mind that could work? Right now I am not too concerned with the fill tube.That can be worked out. Also, having a custom tank built would most likely be far too expensive for my budget.
It must be mounted under the trunk floor. I used to have a 69 Stang and I don't like the idea of the top of the tank being the trunk floor. When I was a kid I didn't know better, but I do now. The fuel cell idea used to be one I wanted to do, but after reading about the lining not lasting very long I would rather not go that route. Although I may end up having to, but it will still have to be mounted under the car. I really want enough trunk space for a 15 inch spare, jack, a small tool box, and a battery. That doesn't leave much room for anything else.
Thanks,
Russ
Thanks,
Russ
