I opened my differential because of a backlash problem especially in 3rd gear and when launching. The 4.10 gear backlash is not so bad, so is the pinion gear.
On the other hand, the side gears are loose as he||! The "pin" holding them is pretty much worn and the gears themselves show alot of backlash.
What can cause this? My differential clutches need to be changed and I made about 10 runs on ET Streets before noticing it. Durain these 10 runs, only 1 wheel spun when heating the slicks.
Did anybody ever have this problem and will changing the clutck packs + side gears solve everything? Are the side gears very expensive?
Thanks in advance for you help.
Best regards,
Yan
Best regards,
Yan
(In a Ranger)
With the proper instructions and low to medium knowledge, would I be able to change them by myself?
