A Motor Question
  • Thread starter Thread starter Synned
  • Start date Start date Nov 10, 2005
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Nov 10, 2005
  • Nov 10, 2005
Okay I'm kind of new at engines and stuff, and I was wondering, how do you assemble the valves, springs, rockers, pushrods and lifters? Like how are they compressed to have pressure? I can't really explain it...
Another question is how is a camshaft degree'd? If anyone can point me somewhere or try to explain...thanks guys. :SNSign:
Autobodypro_1
76
Florida
Nov 11, 2005
  • Nov 11, 2005
Valve train components are normally assembled using a spring compressor to depress the spring so the valve locks will fit into the retainer and slip into the grooves on the valve. The lifters go into the 16 holes in the block, then the heads get bolted on and the pushrods and rockers get bolted on and lifter pre-load is set. That's it in the simplest terms I know however, it requires the skill of a mechanic to do it right. As for degreeing a cam, all that does is insure the correct phasing of the cam in relation to the crank...sloppy or cheap timing chains can upset this phasing. Comp Cams expains the topic on thier web site. I degreed mine when I advanced my cam timing using a degree wheel and a dial indicator.
giddyup306
3,041
Nov 11, 2005
  • Nov 11, 2005
Autobodypro_1 said:
That's it in the simplest terms I know however, it requires the skill of a mechanic to do it right.QUOTE]
Ditto. Do a search or ask hissin50 if onone answers.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine Valve and or rocker noise .....new to this but dont mind getting my hands dirty.
  • mustang matt 1993
  • Jun 29, 2024
2K
Fox 5.0 Mustang Tech Jul 1, 2024
rednotch
