I'm in the process of doing a 5-lug swap, so I figured I'd do some suspension work at the same time.
I am getting FRPP Bullitt suspension kit, so I think I will need to get bigger mounting bushings for the front sway bar. Is this correct, or could I squeeze the larger bar through the stock size 5.0 bushing?
Are the bushing sets from newer Mustangs (ie 99-04 Bullitt, Mach 1, GTs) compatible with a 93 foxbody? In other words, could I just order bushings for a newer car and put 'em in in place of my stock ones?
I'd like to change all my bushings, so I'd like to buy a kit and do as little mix matching as possible. Thanks!
