  • 1994 - 1995 Specific Tech
A9L CPU Question?
  • Thread starter Thread starter DoctorB712
  • Start date Start date Feb 1, 2006
DoctorB712
71
Montreal
Feb 1, 2006
  • Feb 1, 2006
Will changing the CPU on our cars for a previous one like A9L change anything? Also what is the difference between our 94-95 and previous ones?
Thanks to anyone who answers.
blksn955.o
3,263
st.louis mo 314
Feb 1, 2006
  • Feb 1, 2006
there are sev. diff. in the 94-95 computer.
the biggest is the fact the 94-95 is load based and not rpm based...this load is based on the MAF readings and why it is SO VERY important to get a good tune that can get this figure correct.
there are a bunch of fine diff. over the fox ecu.
As far as swapping...its like going from a pentium (one or II) to a 486. It will get the job done and the a9 works well...but once tuned the 94-95 eec is realy quite the good ecu.
HISSIN50
34
129
Feb 1, 2006
  • Feb 1, 2006
Agreed. It would be not unlike going back to carb from an A9 series puter, for simplicity of tuning if not wanting to use computer-aided tuners/chips.
If doing the swap, you would need things like a fan controller, BAP sensor, etc. I would rather tune the existing systems, since it is a much better processor (like BlkSN said) but it is fed a crappy factory tune.
We assume you have a stick too (or a bigger can of worms is opened).
Good luck with the decision. This type of conversion is or was called a PIH kit/conversion (if you desire to search about it).
Good luck.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Feb 2, 2006
  • Feb 2, 2006
One thing worth mentioning also, is if your car is equipped with the AODE transmission, you also need an add-on transmission control device, since the 94-95 EEC handles that duty. I'm not sure what they run, but in my opinion the additional cost of those, plus the PIH kit sort of negates having made the conversion in the first place, since you're still running a factory computer with a factory tune, and will more than likely need a tune down the road when the mods follow the conversion. It might not be a bad idea to read up on some of the self-tuners like the TwEECer or PMS. There's a TON of guys running those with great results and a good tune that spent less out of pocket than going with the PIH.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
Drag strips being sold.
  • Ronin38
  • Oct 12, 2026
  • The Sports Bar
The Sports Bar Oct 23, 2026
rednotch
