Electrical A9P in 5 speed, warm start probs
rocksolid
20
Dayton, OH
Hey guys! I’m in the process of restoring my 88 LX to its original glory (and hopefully more). I had a BAD cold start/stumbling/misfiring issue that I made a thread about, and got that fixed.
Now, it appears I’ve developed a warm start issue, and the car won’t idle when it’s warm. Runs great, and strong... just won’t run when it stops.
Got a code 95, and started the surging idle check list. After testing for vac leaks and moving on, I got to testing wires and it led me to the conclusion that the fuel pump relay was bad. I replaced it, no change. Then I replaced the fuel pump, did a base idle reset, checked my timing and fuel pressure. Still not fixed.
I went to check out the computer and see what was going on, thinking maybe I’d change the relay just out of curiosity and the fact that it’s cheap, and much to my surprise I found an A9P instead of an A9L.
I know these computers work in manual trans cars, but I don’t know if the previous owner did it right. I’m thinking about putting in the correct year A9L, but should I look for anything specific in the car to see if the previous owner swapped harnesses? And do you think this could be my problem?
List of mods:
Mass air conversion
B cam
24lb injectors
Pmas calibrated MAF
C&L ram air intake
Cobra intake manifold
Holley 155lph fuel pump (just put that in)
Literally every single sensor in the engine bay is new, including the TFI module. I did all that when I got the car.
Motor craft plugs and wires are less than two months old with stock spec gap.
Thanks a ton in advance. I’ve learned more from this forum than anywhere else on the internet, so hopefully I can get this figured out.
Was your car originally an AOD car and converted to 5 speed? An original AOD car will/should have the A9P, regardless of what trans is in the car. An original 5 speed car will/should have an A9L regardless of what trans is currently in the car. Sometimes people do 5 speed swaps and are under the impression that they need to change the ECU. You don't, and you shouldn't.
I should have specified but I didn’t think about it, but according to the vin my car was originally a manual transmission. I’m guessing the previous owner had to swap computers for some reason and didn’t know any better?
Transmission code is 2ppss by the way. According to American Muscle, the 2 means manual M5OD (which I didn’t think was ever offered on the Fox), and according to everything else the 2 means it’s a Borg Warner T5. I’m so confused about every aspect of this right now. Hahaha. But either way, it has been a 5 speed it’s whole life.
Unless it is a Cali car it would have been Speed Density not Mass Air. Maybe the A9P was used in the mass air conversion. There are some wiring differences in the 02 harness for the manual vs the auto computer so you might want to verify what you have there. Also the auto parts store IAC gave me issues on my car. Switching to a Motorcraft made a big difference.
The IAC is a Motorcraft, but it never works quite right without an aftermarket spacer, if that information helps at all. Would I be better off getting a computer for an 89 manual car? Or do you think the A9P is fine and wouldn’t cause the issue anyway?
I'd seek out an A9L if you could. You should have no problem selling your A9P to recoop cost.
Confirm your O2 sensor harness jumper. It's located right under the MAF. 1988 was an odd year as the harness jumper could be missing like 1987 cars (in which case no need to worry about it) or present like the 1989 later cars, in which case you need to make sure it's positioned for a 5-spd car when you plug in that A9L.
See this thread on how I repined my harness on my '88 when I converted from automatic to a A9L 5-spd ECU when I did my mass air swap
https://stangnet.com/mustang-forums/threads/o2-harness-repin.908182/
The A9P if it it is working properly, will do OK. There are some minor differences in the way it handles the slow down the engine when you come to a stop
When the car won't start, do the checklist below....
Cranks OK, but No Start Checklist for Fuel Injected 5.0 Mustangs model years 1986-1995
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 26-Jul-2017 to add fuse link diagram.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD, Crane, or other ignition box if present - Bypass it and return to stock configuration if possible. Do this as a temporary measure to eliminate it as a possible problem source.
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer. Don’t replace the computer just because you don’t understand how it works. Computers seldom fail, it usually is a sensor or wiring problem that causes the problems.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red/blue wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the Ignition switch wiring diagram for more information on the ignition wiring fuse link because it is the next thing to be tested. You will need a Multimeter or DVM and know how to use the Ohms function to check continuity between the red/green wire on the ignition coil and the red/green wire on the ignition switch. Make sure that the ignition switch is in the off position when you do the check. You should see less than 1 Ω (Ohm) between the red/green wire on the coil and the red/green wire on the ignition switch. More than 1 Ω means that the fuse link may have blown open and needs to be replaced. If you get 1 Ω or less means the fuse link is OK and the ignition switch is bad.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachments\68357
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
B.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
C.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
The injector power pin is the VPWR pin in the black 10 pin connector.
D.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
E.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it, if you get this far. If it starts, replace the ECT.
Started the new checklist last night, going to try to get through some more of it today. Before I started, I pulled the codes again just to be sure. After a new fuel pump and new fuel pump relay, I’m still getting a code 95. And I did reset the computer and drove it around a little before hand. A little bit interesting I guess. Haha
Mass air swap car right?
Unless you physically run a wire from the fuel pump relay pink/black to the ECU pin 19, you will always get code 95.
This, plus the VSS wiring are usually overlooked when a car is mass air swapped. I would definitely recommend verifying the VSS connections to the ECU.
Honestly I think the previous owner got lazy with that, because the speedo doesn’t work. Doesn’t even move a little bit. VSS is plugged in and so is the speedo cable, so something isn’t right with that. I planned on tackling that after getting it running right. Unless that could be a contributing factor... but it only just recently started doing all of this stuff, so I’m just not sure.
VSS plugged in doesn't mean it's giving feedback to the ECU. 1988's lack the wiring in the actual body harness over to the ECU. It was only used for cruise control purposes on speed density cars, so no need to wire it to the ecu.
Ok. So no need to worry about it right now because there’s no way it’s jamming me up? Besides the non-working speedo, which I irresponsibly don’t care about at the moment.
With mass air, the VSS comes into play when rolling to a stop. Without it hooked up, some report the engine may stall out.
But you've run the codes, and no VSS code came up correct? If you aren't stalling when stopping, I wouldn't worry about it. If you ever notice that you do start stalling...here's where to look
