  • 2.3L (N/A & Turbo) Tech
about my turning signals.
  • Thread starter Thread starter Foxfan88
  • Start date Start date Dec 28, 2004
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Dec 28, 2004
  • Dec 28, 2004
Ok when i first got my car back about 3 months ago, the turn signals would act funny, one day the left wouldnt work, the next day the right.
Then they both worked perfectly until today.
the left one works fine, but the right one wont click, it just lights up and wont blink.
Any recommendations?
Dr_EluSivE
2,155
Central Illinois
Dec 29, 2004
  • Dec 29, 2004
you probably have a bulb out, check all your exterior bulbs. If they are all ok i would say replace the flasher.
Dr.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Dec 29, 2004
  • Dec 29, 2004
Must be the flasher, because i can manually flash it if i move it up and down.
Dr_EluSivE
2,155
Central Illinois
Dec 29, 2004
  • Dec 29, 2004
not nessisarily, If you have a bulb out there will not be enough load on the flasher to make it blink. Turn on your hazards and check all your exterior bulbs and make sure they are working. the flasher will do what you describe to try to "tell" you that a bulb is out. If all bulbs work then replace the flasher, but if one direction works and the other doesnt then your flasher is probably ok.
Dr.
Stinger
7,754
24
118
Basehor (Kansas City), KS
Dec 29, 2004
  • Dec 29, 2004
Check your blinker fluid too...could be low...
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Dec 29, 2004
  • Dec 29, 2004
We looked today and the right rear bulb was loose
so we tightened the bulb and viola, it works now!
kiddiccarus
The first widely accepted Tranny
20+ Year Stangneter
Dec 24, 2003
1,789
1,051
143
30 Mins from a Ragged GT
Dec 30, 2004
  • Dec 30, 2004
I checked the blinker fluid and found that the right front head lamp was a little fuller than I liked so I had to drill a small hole in the lense at the bottom to even out the air/water ratio.
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
68 horn and turn signals stopped working
  • connella08
  • Sep 10, 2025
Classic Mustang Specific Tech Sep 10, 2025
Z
Turn signals not working at all, but hazards do. 91 fox LX 5.0
  • Zeke1995
  • Jun 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
Jarhead67
J
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
