  • SN95 4.6L Mustang Tech
? about Pi swap
  • Thread starter Thread starter TangerineGT96
  • Start date Start date Sep 27, 2005
TangerineGT96
134
arkansas
Sep 27, 2005
  • Sep 27, 2005
i got a 96 GT that im wantin to put Pi heads on and im wonderin what all i need and if the timing chain,timing change cover,timing chain runners(plastic things)vavle covers and all the other good stuff would work
Orions98GT
234
Overland Park, KS
Sep 27, 2005
  • Sep 27, 2005
if you do a search you can find a lot of threads pertaing to this topic, but you will need, the heads, intake manifold, a large bit to tap the hole for the water temp sensor, head gaskets, intake manifold gaskets, plus some other small stuff. I went ahead and replaced my timing chain set while it was apart for $350 from Orilleys, better safe then sorry.
DropTopPony
Noob Slayer
2,570
south jersey
Sep 27, 2005
  • Sep 27, 2005
new explorer PI engines are going for 1995 now that about what it will cost you to buy the PI headswap kit 1399 plus upgradeing your old timing euipment etc...why not just drop a new motor in with an aluminum block. If these were available when i did mine this is the route i would have chose...
http://karkraft.com/engines.htm
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Motor ID
  • 65er
  • Mar 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 14, 2026
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
M
Timing chain loose on top passenger side
  • MustangD0M
  • Mar 18, 2025
1996 - 2004 SN95 Mustang -General/Talk- Mar 26, 2025
89ripper
