Ok... Well I been chasing down a problem which I thought was in the timing and now i'm leaning more towards a fuel problem. Say i'm driving, my car feels strong up until about 4500rpms. When it reaches that rpm it kind of feels like a misfire or a rev limiter but isn't really any of those things, it shoots up really fast and you can tell there is no fuel being used all you can hear is air. It basically bogs and I can't go no where. Right now i'm running 14 degrees timing, my distributor is set perfectly on TDC on the #1 compression stroke, also everything on my ignition system has been replaced.
The fp gauge that mounts to the sharder valve isn't going to help me much really. I heard about getting a mechanical gauge and temporarily mounting it on the outside of the vehicle somewhere but the problem is something I kinda want to monitor a little more extensively. In other words I don't really want to have my hood half cocked open with a mechanical fp gauge duct taped to my window for 2 weeks.
The air/fuel gauge I was planning on getting a separate wideband o2 sensor and mounting it in my prochamber specifically for the ait/fuel gauge. Say my fuel pressure gauge reads normal when my problem occurs, if the problem were say in the injectors then the air/fuel gauge would read lean from the o2 sensor. I personally think it would help me determine more where the problem is... unless i'm wrong?
I don't know, i just figured it would be the best way to go about monitoring the problem with my car. And of course it would help me in the future. Thanks for the help though
