Ok i have bought the M/T Et streets for when i go to the track and I was going to buy the Weld Xp's (prostar) and I m pretty sure that I need or should put on the 3" studs so I get more threads right? Well question is can I put my other 17" wheels back on with the 3" studs w/o a problem??? Also how hard is it to change the studs because a guy told me the other day they have to be drilled out and then to put a new set in you might have to take out the axles? Is this true? I always thought it was just a simple wheel swap to put the wheels/slicks on and then I was told to get the 3" slicks or they would fall off and do tons of damage....so I thought I would have to change the studs everytime i change the wheels and this guy is saying thats LOTS of work and that i may even need to get the axles out to do this and i definetly dont wanna do that so anyone know if I can use the 3" studs for the 15x8 prostars and then put my 17's back on w/o changin or w/o problems???? Thanks in advice I know this is long put I need the info fella's
I'll just get the new axles w/ 3" studs already installed...Im running some Eagle 5 stars cuz I think they look better than the Cobra R's so I traded them in and they dont have covers over the lugnuts so I should be good right?
