? about welders
  • Thread starter Thread starter Beaka Bo
  • Start date Start date Nov 2, 2006
Beaka Bo
  • Nov 2, 2006
I'm new to the site and I need to buy a welder. I just purchases a 67' convertible. It's in bad shape. I'm looking at the lincoln 3200 HD (25A-135A) says it welds up to 5/16 with flux cored wire but I plan to use steel wire with gas. I just want to know if the 135 is capable of welding anything I need to weld on the car from frame rails to quarter panels. I plan to buy all new parts from NPD as almost everything on the car needs replacing. Thanks for any help.
Also if the welder says it weld from .24 to 5/16 will it still weld smaller metal?
Skyes 66
25
Kansas City Metro Area
Nov 2, 2006
  • Nov 2, 2006
Check out this thread: http://forums.stangnet.com/showthread.php?t=667942 its on this forum.
IMO yes it is large enough to weld anything on a mustang, the frame rails on a stang (to my knowledge) are less then 1/4" thick so you should be fine. As far as wire selection and what it will weld you will have to look at each welder and what setting for the different wire sizes and types. The HOBART™ HANDLER 125 EZ from Tractor Supply (TSC # 3806489) can weld from 18 ga - 3/16 in with a flux core wire, but with the mig conversion it can weld 22 ga with a solid wire which is what you need to handle the 19 ga metal for floor pans and such even though it is rated at 30 amps and not 25 amps. Heres a link to Hobarts mig welders http://www.hobartwelders.com/products/mig/ and a link for the what I believe is the welder you pointed out http://content.lincolnelectric.com/pdfs/products/literature/e721.pdf look at the table on page 2 it shows the wire size/metal thickness/gas requirements. Other welders say the upper amp output should be 180 or so enable to weld 5/16th inch thick.
Clear as mud?
Skye
xoxbxfx
3,959
Southlake, TX
Nov 3, 2006
  • Nov 3, 2006
it will be plenty to weld anything you will ever need on that car. Make sure you get the gas... flux welding sucks
Beaka Bo
  • Nov 3, 2006
Thanks for the replies. I settled on the lincoln 135 mig. picked it op at home depot this afternoon. $491.00 out the door came with a cart(for welder and a bottle) and two rolls of wire all I need to do now is learn how to use it
xoxbxfx
3,959
Southlake, TX
Nov 3, 2006
  • Nov 3, 2006
get your gas ASAP... welding without is totally different
Beaka Bo
  • Nov 4, 2006
Found a bottle at a local place here in Tampa. $120 filled
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
E
New Member with 91 foxbody
  • EricMac13
  • Jul 22, 2025
  • The Welcome Wagon
The Welcome Wagon Jul 23, 2025
EricMac13
E
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
