I have a 2002 Mustang GT and the ABS lights stays on and some times goes off after a while but when its is on the track control does not work as well what could be wrong ?
Mine has,topped it off,and gone with the abs light.DTMach1 said:brake fluid will not illuminate your ABS light.
1low03gt said:Mine has,topped it off,and gone with the abs light.![]()
There is a sensor on the side of the reservoir,and if your fluid isn't topped off properly,it(the fluid) will slosh forward while braking,and trip the sensor to come on.It's actually pretty common.![]()
1low03gt said:Well i know that!!
....But the abs light came on!!Put fluid in it,and it no longer came on.
DTMach1 said:That's the brake light...brake light = red...ABS light=orange
Two different indications.
ABS light = inoperative ABS system
Brake light = E-brake engaged or Brake fluid low
svttech76 said:The ABS light can illuminate if the brake fluid is low, for example windstars when they are low on brake fluid will illuminate both. Some fords are more sensitive to how long the fluid has to be low to deactivate the abs, this is done to protect the HCU and for saftey concerns
