  • SN95 4.6L Mustang Tech
ABS light
  • Thread starter Thread starter rolenna00gt
  • Start date Start date Aug 13, 2004
R
rolenna00gt
196
k-town tn
Aug 13, 2004
  • Aug 13, 2004
Ok so I took my car to my mech. today (Robert Hindman aka Mod motor champ) to get the codes pulled so I can get my ABS light to go off, he said he hooked the scanner up to the car and it wouldn't do anything he said it reads fine, and he doesn't know why the light is on he also checked my ABS sensors to make sure they are good which they were, so we are both stumped and suggestions or anyone else have the same problem..
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Aug 13, 2004
  • Aug 13, 2004
I still bet one of the sensors is bad or a wire came loose. The rear sensors connect to a harness under the rear seat. Just pull the seat up and see if the connections are good. If I find the link on how to test them I'll post it. I have it at home somewhere...
R
rolenna00gt
196
k-town tn
Aug 13, 2004
  • Aug 13, 2004
Thanks that would help alot
R
rolenna00gt
196
k-town tn
Aug 14, 2004
  • Aug 14, 2004
No one else have any suggestions on what is wrong or what to do?
BVille99GT
283
Brownsville TX.
Aug 14, 2004
  • Aug 14, 2004
I'm interested too, I have the same problem. I kinda got used to it dough.
H
HeyLittleCobra
46
Pennsylvania
Aug 14, 2004
  • Aug 14, 2004
I put bigger rear tires on my car once and almost instantly I got an ABS light. Keep in mind I went from 26 inch tall tires to 28 inch tall BFG Drag Radials...You say you have 275/40's....They are still just about as tall as the 245/45's...I dunno...Just a thought.
XTONKAX
619
UT
Aug 14, 2004
  • Aug 14, 2004
When I had an ABS light I didn't pull any codes either. I then took it to an ABS/Brake specialist shop and they told me an ABS code wouldn't show on a normal reader. Long story short, I had a bad sensor and bad connections into the ECU. They replaced the bad sensor and cleaned up the connections with some electrical grease.
Good luck!
R
rolenna00gt
196
k-town tn
Aug 15, 2004
  • Aug 15, 2004
How much did that cost?
XTONKAX
619
UT
Aug 15, 2004
  • Aug 15, 2004
I think all told, it was around $300. About $85 of that was the initial diagnostic. It could have been much worse in my case since they had trouble locating the problem of the ECU connection. They didn't charge me for a lot of the time they put in.
Best to pay for the diagnostic to see if they can find the specific problem.
O
ABS light on. Can't get codes
  • oldtimeracer
  • Jul 12, 2024
4K
SN95 4.6L Mustang Tech Aug 28, 2024
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Saturday at 5:19 PM
manicmechanic007
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
ECU help!
  • starkiller1134
  • Aug 16, 2025
SN95 4.6L Mustang Tech Aug 17, 2025
starkiller1134
Brakes ABS in a Fox - Mark Bettin
  • AeroCoupe
  • Mar 28, 2025
Fox 5.0 Mustang Tech May 17, 2025
AeroCoupe
