  • SN95 4.6L Mustang Tech
ABS Sensor problem after rear end swap
  • Thread starter Thread starter Rusty67
  • Start date Start date Aug 19, 2006
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Aug 19, 2006
  • Aug 19, 2006
Ok, so I finsihed swaping the 7.5 out and the 8.8 in to my 99 v6 daily driver. The rear end I used was from a 95GT. I ended up needing new axles and bearings so I bought a set from superior and had the shop put the old tonerings and lugs onto the new superior axles. So after all my rear end modification and I've got EVERYTHING back together and think I'm done, I got to put the ABS sensor back in and the head of the sensor knocks against the tone ring. so even if I could bolt it down it would be ground to bits by the tone ring. I made sure there axles were made for abs, I called superior and asked them. It looks like there is enough space to press the tone ring further down. I talked to the shop that put the rear end together and they said to drive the car down monday and they would look at it.
For now, I've zip tied the abs sensors to the parking brake cables and they clear everything. Of course, my abs warning light is on. The questions are, should I pull my abs fuse until I get this fixed ? My brake pedal feels a bit funny now. Secondly, do I need to use an abs sensor from the 95GT or should I be using the abs sensor for my car ? Does anyone know if they are phyiscally different ? When I took the 95GT apart, they looked exactly the same.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Aug 20, 2006
  • Aug 20, 2006
If I used a metal washer to space the abs sensor back would it throw the sensor off since it is magnetic or would the plastic body shield it enough ? It does go through a metal backing plate... Would this be a good temporary fix for my problem ?
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
O
ABS light on. Can't get codes
  • oldtimeracer
  • Jul 12, 2024
4K
SN95 4.6L Mustang Tech Aug 28, 2024
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
