I have solved my own problem, before I was going to post it on here.
Tonight I was out driving and the ABS and the Traction control light were on steady. I stopped quick and sure enough came to a screcching halt. I unplugged the battery cable to reset the computer, but the lights still remained on afterI reconnected it.
I was then thinking what could have happened and remebered that earlier today I installed some LED light pods in my back seats, Ihad removed the lower seat cushion in order to run the wiring. I also found a huge amount of debris, leaves, coins and lots of other crap collected under there. While vacuuming out the space under the seat, I disconnected some wires and forgot to replug them in.
I just went out, removed the seat, found the unplugged wires and reconnected them. The ABS/Traction lights are now off and working fine.
These wires were connected to the ABS sensors under the car.
I hope this helps anyone who has this problem.
Also... if you own a convertible, you should see what crap has collected under your rear seat. It is easy to remove...if you know how. Thats another posting.
ROB
ROB
