Absolutely Frustrated...
  • Thread starter Thread starter blascrw
  • Start date Start date Oct 25, 2004
First Prev 2 of 2
D
D.Hearne
11,730
south louisiana
Oct 26, 2004
#21
  • Oct 26, 2004
  • #21
And if you can, find a set off a 70's motor, they had taller covers than the later 80's EFI versions
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
Oct 26, 2004
#22
  • Oct 26, 2004
  • #22
I found the 10.00 Rocker clips to work just fine.
Keeps the oil from spurting.
If you can idle it down to below 800 rpm the oil will stay flowing back
to the pan.
PB
blascrw
191
Opelika, AL
Oct 26, 2004
#23
  • Oct 26, 2004
  • #23
Rocker clips?
rocker clips??
Not sure as to what you are speaking...
Ron
stephen4785
321
Fort Worth Texas
Oct 26, 2004
#24
  • Oct 26, 2004
  • #24
http://store.summitracing.com/defau...0&Ntk=KeywordSearch&Ntt=rocker+clip&x=18&y=10
there you go. You just clip these on the end of the rocker with the plastic shoving in the top of the pushrod
Max Power
1,774
St Paul
Oct 26, 2004
#25
  • Oct 26, 2004
  • #25
I just threw a set away yesterday, I would have given them to you. Bummer.
stephen4785
321
Fort Worth Texas
Oct 26, 2004
#26
  • Oct 26, 2004
  • #26
If you decide to get a set then get some rubber badns and wrap it around them the best you can to get them to stay on.Some times they fly off.
G
gerno
14
#27
  • Oct 27, 2004
  • #27
You say there's a mild cam in it. Which rockers are you using? Perhaps if you don't have the long slot arms the rockers are hitting the studs. I had this problem once and it drove me nuts.
Just a thought.
D
ddtforu
37
Santa Clara, ca
Oct 27, 2004
#28
  • Oct 27, 2004
  • #28
as they said check easy stuff
One thing I would verify is that all the plug wires are truly on in the right order. May sound too simple, but I've seen it happen before, even by experienced mechanics, who spent a lot of time chasing down a miss by overlooking something simple.
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Oct 27, 2004
#29
  • Oct 27, 2004
  • #29
D.Hearne said:
To do it running, you really need to take an old steel valve cover, then cut the top off, and bolt it in place before trying to adjust them while running. Then start the motor, and doing them one by one, tighten them down till it misses, then back off til you hear the rocker clatter, then tighten 3/4 turn.
D, I usually just lay a shop rag over the rockers, it shouldn't take more than a few minutes to adjust the valves. Shouldn't make to much of a mess
blascrw
191
Opelika, AL
Oct 27, 2004
#30
  • Oct 27, 2004
  • #30
OK how to do it...
Ok What is the procedure for adjusting them while running?
Is the procedure in the chilton's? I have not had the time to read and see...
Ron
Max Power
1,774
St Paul
Oct 27, 2004
#31
  • Oct 27, 2004
  • #31
The procedure is above in this thread...
D
D.Hearne
11,730
south louisiana
Oct 27, 2004
#32
  • Oct 27, 2004
  • #32
Ron
Am I missing something here? Or did he miss something ? Or as Bill Engvall say's......."There's
your sign".....................
Max Power
1,774
St Paul
Oct 28, 2004
#33
  • Oct 28, 2004
  • #33
LOL!!
allcarfan
The Answer Man
2,458
North Atlanta
Oct 28, 2004
#34
  • Oct 28, 2004
  • #34
Ron,
If you are still having problems in a few weeks, let me know. I will let our club know and we might be able to make a trip to Opelika on a staruday and make it a club event.
I was in opelika the other day, but didnt have your number. it was a spur of the moment trip.
Shane
ssppiitt
206
Mountain View, Ca.
Oct 28, 2004
#35
  • Oct 28, 2004
  • #35
This may be too simple but did you try checking your belts for wear and tension? They could be throwing everything off.
HistoricMustang
2,359
Confederate States of America
Oct 28, 2004
#36
  • Oct 28, 2004
  • #36
Did you change the fuel lines (under the car) after the long sit?
HistoricMustang
www.historicmustang.com
blascrw
191
Opelika, AL
Oct 28, 2004
#37
  • Oct 28, 2004
  • #37
ok...
Sorry I have not had a chance to do anything. My wife had a baby on Friday and then the baby we re-admitted to the Hospital On Tuesday. She has/had Jaundice pretty bad...hopefully she will be home in a day or so.
I was asking the procedure for adjusting the valves while running. I did not see it in the prior threads...Now re-reading this thread for like the 100th time I see D.Hearne's post...
I did not change the steel lines..I did put a new in line fuel filter, and and new rubber lines.
Shane...thanks for the offer, but this weekend will not be a good idea read above...maybe next weekend if I don't have it going by then.
Thank all of you..
I think my issue is with the valves...I THOUGHT I read that you tighten until you cannot turn by fingers and then 3/4 turn more...and that is not the case...therefore I have likely over tightened all the valves.
Ron
Max Power
1,774
St Paul
Oct 29, 2004
#38
  • Oct 29, 2004
  • #38
Congrats on your child Ron!
ssppiitt
206
Mountain View, Ca.
Oct 29, 2004
#39
  • Oct 29, 2004
  • #39
Now you have three ladies to take care of. Don't worry I have 5 ladies. Only one being my stang. Sometimes it is hard when there is not a enough testosterone around. That's when you just leave the house. LOL!!
M
MistaMadMike
30
#40
  • Oct 29, 2004
  • #40
have you adjusted that thing yet? if ya overtighten youll bend a rod and bind a spring. Off of what D.Hearne was saying..(my addition) You can do it with the car off as to tightening until the pushrod cant move so its a lil more than snug. Then, you start the car and tighting until it stops clacking to be at zero. If its not clacking back off of it until it clacks and then tighten until it stops and then do 1/2 turn at first. 3/4 turn would be the most i'd go but I would go 1/2 and take note of how its reacting and then go 3/4 to see the difference. After the car has heated up to operating temp, you might wanna re-check the lash again. Thats how I would do it..
Ron
First Prev 2 of 2
Electrical Dash wiring
  • RileyDymond
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 19, 2026
RileyDymond
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
