AC causes car to over heat
  • Thread starter Thread starter bdemat
  • Start date Start date Jul 15, 2020
First Prev 2 of 2
Dan02gt
mazing how much gas smell came from that tiny hole
20+ Year Stangneter
Mar 2, 2003
909
415
113
Greenville, NC
Jul 20, 2020
#21
  • Jul 20, 2020
  • #21
Did you make sure no one installed under drive pullies on it at some point?
KRUISR
1,860
995
143
Jul 20, 2020
#22
  • Jul 20, 2020
  • #22
I agree with General karthief, your fan and shroud look fine. The fan needs to be in the cylinder section of the shroud. If it is not it will not pull air. Yours is fine.
Looking at the pics, how old is the rad and how thick is the core?
I would get a very small screwdriver or thin putty knife and try to clear that paint out of your condenser.
Another thing to check if your A/C is charged enough, when car is idling with A/C on Max does the clutch stay engaged for long periods of time. If not (it cycles on/off often) you likely are low on refrigerant. I just did this on my truck. It was same thing, cooler when moving and less cool when stopped. I added a 9oz can of refrigerant to my truck and now will blow cold (will get down to 6 degrees Celcius out vents).
General karthief
Mod Dude
Aug 25, 2016
28,048
10,672
213
polk county florida
Jul 20, 2020
#23
  • Jul 20, 2020
  • #23
I bet you have two problems
#1 ac low on feon
#2 you may or may not have an overheating problem, you need to put a mechanical temp gauge on it to see actual temp numbers, you can zip tie it to the wiper arm temporarily.
It would not be unusual for the engine temp to get to 210-215 sitting still with ac on.
And I'm betting you have under drive pulleys too.
bdemat
20
Acworth ga
Jul 21, 2020
#24
  • Jul 21, 2020
  • #24
No underdrive pulleys. I am really at a loss at this point. Everything looks like it should be good. I am changing the Ac clutch bearing because it makes a lot of noice but i dont think it will make a difference.
bdemat
20
Acworth ga
Aug 2, 2020
#25
  • Aug 2, 2020
  • #25
So i am on my second fan clutch,,i don't know the exact temp , my cheap temp gauge says its 210 when i point it at the thermostat housing. And the clutch is not engaging. Possible 2 new clutches are bad? Or maybe the water isn't circulating through the radiator at idle fast enough?
General karthief
Mod Dude
Aug 25, 2016
28,048
10,672
213
polk county florida
Aug 2, 2020
#26
  • Aug 2, 2020
  • #26
Is it stay'n at 210* or does it keep going up?
bdemat
20
Acworth ga
Aug 2, 2020
#27
  • Aug 2, 2020
  • #27
It was still going up
LX Dave
5 Year Member
Jul 2, 2017
240
182
53
Aug 2, 2020
#28
  • Aug 2, 2020
  • #28
Just went through this with my car, even though I don't have AC, it would run really hot while idling.
Engine - Another cooling system thread
Hey guys, I'm having an annoyance with my '84 Mustang. When going down the road, the cooling system has no problem keeping the engine cool (normally runs between 197-203 degrees) with a Motorcraft 195 thermostat. The problem starts when I have to sit and idle for more than a couple of...
www.stangnet.com
Even though I had a new fan clutch on, it was new bad. Details in the thread what brand I was running and where I got a good one.
General karthief
Mod Dude
Aug 25, 2016
28,048
10,672
213
polk county florida
Aug 3, 2020
#29
  • Aug 3, 2020
  • #29
I think 220* sitting still with the ac on would not be unusual, point the temp gun at the bottom of the radiator near the lower hose.
Temp measured at metal parts will be a few degrees higher than coolant temp. I've used a meat thermometer between the shroud and the radiator.
Mindseye007
10 years still blowing strong
5 Year Member
Oct 21, 2020
586
137
63
ontario
Oct 21, 2020
#30
  • Oct 21, 2020
  • #30
I had a similar problem I fixed it by getting a flex a lite electric fan installed https://www.flex-a-lite.com/direct-...-electric-fan-for-1979-1993-ford-mustang.html my overheating problems are solved are you running underdrive pulleys? I run underdrive pulleys with no problems at all.
First Prev 2 of 2
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
W
High Cylinder Head Temp - Not Overheating?
  • wtfwork12
  • Jun 26, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Jul 1, 2025
wtfwork12
W
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
J
V-6 thermostatically controlled cooling fan - on when cold - new behaviour
  • jacekk
  • Oct 1, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 1, 2025
jacekk
J
