Ac clutch turns on on it own.
If the wiring in the WOT-relay-socket shorts (because the wires get hot and the insulation vulcanizes), you can short the coil's positive-input to the normally-closed terminal, causing the clutch to engage.
Also check the LPCS because the wires and top of the connector can get gooey and nasty.
Good luck.
